Comptech IceBox + intake kit??
Old Jun 12, 2002 | 07:26 AM
subliminizm's Avatar
Default Comptech IceBox + intake kit??
Can someone please explain what is necessary to have the Comptech Icebox installed?
I heard that besides the Ice Box you have to buy the regular intake kit too? Is this true? Is the Ice box, simply a Cold-Air extension piece? So for just the parts it would be $360?
[Modified by subliminizm, 4:27 PM 6/12/2002]
Old Jun 12, 2002 | 08:37 AM
Austin's Avatar
Default Re: Comptech IceBox + intake kit?? (subliminizm)
You just need to purchase the "Ice Box", no need to purchase the intake tubing.
Old Jun 12, 2002 | 08:40 AM
Nate B's Avatar
Default Re: Comptech IceBox + intake kit?? (Austin)
You can run the icebox without the short ram, but you'll get a better power gain if you use the shortram and comptech filter along with it.
Old Jun 12, 2002 | 08:46 AM
Default Re: Comptech IceBox + intake kit?? (KILLERB18)
shoot, so $360, huh!
I really like the fact that the Comptech is quieter than the AEM, has about the same power numbers, and is a little safer. But its gonna cost more than $120 more than for an AEM CAI equipped with By-Pass valve.
So half of it is going to be metal tubing and the other half will be plastic?
You guys think its worth it?
Old Jun 12, 2002 | 08:48 AM
Austin's Avatar
No need to run the aluminium piping...to start you can even run the stock air filter.
Old Jun 12, 2002 | 08:54 AM
I realize that, bu then it won't pick up cool air, it would just be a short ram, and it wouldn't help much with power gains as the CAI setup would.
What I am asking is: Is the extra money worth it for the full Comptech setup, or should I just go for the AEM with bypass valve. I guess if its significantly quieter than teh AEM, and provides better safety, and equal or better performance, it might be worth it.
Old Jun 12, 2002 | 09:03 AM
Austin's Avatar
Just get the box at $169.00 retail.
You do <u>not</u> need this:
[Modified by Austin, 10:03 AM 6/12/2002]
Old Jun 12, 2002 | 09:22 AM
So is this what everyone is doing, just using the Ice Box with the remainder stock piece (piping that runs from box to Intake Manifold)?
Old Jun 12, 2002 | 09:29 AM
Austin's Avatar
Yep...just using the stock rubber intake elbow. I have the full kit, but that was before Comptech found out(on my car) that the aluminium intake piping was not needed.
Austin
Old Jun 12, 2002 | 09:48 AM
reefer_bob's Avatar
I have the Aluminum Pipe and the Ice box... I like the bling bling effect.... Actually I'm just a Comptech *****, so it's all good!
To back up Austin, you can just use the stock hose and the ice box. Fits fine. You might want to get a K&N though...
Old Jun 12, 2002 | 11:04 AM
dphi's Avatar
That, or buy a cheap short ram and a filter and you're done. And now that you know that, I'll sell you a carbon fiber short ram for $30
Old Jun 12, 2002 | 11:13 AM
hybridreams's Avatar
Default Re: Comptech IceBox + intake kit?? (dphi)
Good info guys
Old Jun 12, 2002 | 12:09 PM
thashadow's Avatar
Default Re: Comptech IceBox + intake kit?? (hybridreams)
how does the icebox and the aem short ram compare to each other, whe it comes to performance, realiablity, maintenence and anything else?
jdmek09
Nov 21, 2005 03:14 AM
pat.ter.rick
Aug 27, 2005 11:12 PM
SIK IN DA HED
May 14, 2004 09:20 PM
tb_pimpjuice
Oct 16, 2003 10:32 AM
ITR.00-1282
Aug 31, 2001 04:13 PM
