Trying to save money...Need help identifying transmission parts!! (5th gen) :P
I went to honda and they told me that I need to pay them about 200 dollars for a couple bearings, and a shift fork(the fork is for 1st and 2nd gears). Could someone identify these parts for me? I know there are junkies out there that know these part numbers. I really need to find a place that can save me money, I need this car fixed asap, please any input would be accepted!
Thanks guys, I really appreciate all your help!
Basically its the mainshaft bearing, and where the mainshaft goes through to the clutch side of the transmission.
First one is commonly known as the ISB (input shafe bearing).
Second is the 1/2 shift fork like you said.
Third is the top countershaft bearing.
http://hondaautomotiveparts.com
or
http://acuraoemparts.com
Just follow the illustrations. It's easy.
or
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpaton »</TD></TR><TR><TD CLASS="quote">First one is commonly known as the ISB (input shafe bearing).
or
Just follow the illustrations. It's easy.</TD></TR></TABLE>
Thank you very much! I really appreciate it!
or
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpaton »</TD></TR><TR><TD CLASS="quote">Third is the top countershaft bearing.</TD></TR></TABLE>
Mainshaft angular ball bearing in the third picture. Countershaft is in plain sight below with all its bearings on there.
P20/A000 case, make sure you order the correct bearings.
Likely the outer mainshaft bearing won't need replaced, it's normally a little sloppy.
I can get the EXACT part numbers you need.....but they might be out of stock
I bought over $1000 in bearings and seals last night, everything is being shipped from Cali now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowcivic2k »</TD></TR><TR><TD CLASS="quote">Mainshaft angular ball bearing in the third picture. Countershaft is in plain sight below with all its bearings on there.</TD></TR></TABLE>
Oops, you're right. For some reason I had that picture upside down in my head.
