exhaust problem???
ok so when i first bought my car it had a loud nasty sound coming out of and i saw there was a whole in the muffler and changed it but then i found it was still a nasty sound coming from close to the cat so i went to muffler shop they fixed it... and again that same spot like before the cat went bad again its leaking and sounds horrible im pissed and dont understand why that leak keeps coming back what could it be??
oh and by the way my car has high emissions if that has anything to do with it... thats the only explanation i could find... every time i shift i hear the exhuast leak letting off a pop... and my car backfires when its slowing down needless to say it sounds like ****
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by viskii420 »</TD></TR><TR><TD CLASS="quote">what year civ is it?</TD></TR></TABLE>
You know what year the civic is now so answer his question
Is all you hear the backfiring and popping? Cause my car does that, but it doesn't have an exhaust leak.
Or is there a true leak?
Have you checked the gaskets on both sides?
It's still puzzling why the leak would come back though. I can only think rust. Or your typical drive would involve a bump somewhere that would slowly dick up the exhaust eventually resulting in a hole. Hmm...this is a tough one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jakester9500 »</TD></TR><TR><TD CLASS="quote">Is all you hear the backfiring and popping? Cause my car does that, but it doesn't have an exhaust leak.
It's still puzzling why the leak would come back though. I can only think rust. Or your typical drive would involve a bump somewhere that would slowly dick up the exhaust eventually resulting in a hole. Hmm...this is a tough one.</TD></TR></TABLE>
it is a tough one bro... and its funny because its not a hole its the little gasket between the piping that keeps going bad no matter how many times i change it im about to just throw a straight pipe in it and call it at day
You're in new york... everything on your exhaust is probably rusted to **** if it's the stock 93 exhaust, or even been replaced once before. The whole cat back is like $200-250 for OEM replacement. Without the muffler it's probably $125... Fresh metal will last you another 5 years before it rusts through again
Try a better gasket. Like the cork kind. They seem to hold up pretty well from what I have seen.
Maybe your flange is fucked up that it isn't making a flush connection though. I would say screw it and have the muffler shop just weld it up.
mojackson2390
21
Aug 15, 2008 11:28 PM
