autometer temp guage
Old Aug 9, 2007 | 03:30 PM
crxfreak1117's Avatar
Default autometer temp guage
where do u screw the end of the temp guage at on a b16a is it on the back of the block or what?
Old Aug 9, 2007 | 03:39 PM
APEX CRX's Avatar
Default Re: autometer temp guage (crxfreak1117)
Temp gauge for what? water?
Old Aug 9, 2007 | 05:41 PM
Crx Jimmy's Avatar
I made an adapter from the hardware store to go in the 5/8 hose that is "looped" in back and screwed it into that. the hose is the one from the block to the head.
Old Aug 9, 2007 | 05:48 PM
Mr.Death's Avatar
Default Re: autometer temp guage (Crx Jimmy)
I tapped into the hose which goes to the heater core.
Old Aug 10, 2007 | 08:22 AM
Default Re: autometer temp guage (Mr.Death)
how exactly do u tap it in????
Old Aug 10, 2007 | 02:30 PM
Tippyman's Avatar
With a tap.
Old Aug 10, 2007 | 02:51 PM
Mr.Death's Avatar
Default Re: autometer temp guage (Tippyman)
Like so.
Installed.
Any questions?
Old Aug 10, 2007 | 04:38 PM
1QuikSOHCZC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Death &raquo;</TD></TR><TR><TD CLASS="quote">I tapped into the hose which goes to the heater core.</TD></TR></TABLE>
I thought it was better to tap from the upper rad hose because its a more accurate temp??? what does ur gauge read at operating temp? just curious to see if theres a slight diff in readings.
Old Aug 10, 2007 | 04:53 PM
Crx Jimmy's Avatar
Default Re: autometer temp guage (1QuikSOHCZC)
I wouldnt use the heater core hose because it has a valve in it to stop th coolant from going though so you dont have the heat on all the time. this would work ok if you left your heat on all the time. do the same thing in the pic but to the looped hose I talked about earlier.
Old Aug 10, 2007 | 05:55 PM
Mr.Death's Avatar
I have my heat full open all of the time with the fan off. Works for me.
loweredimages
Aug 31, 2013 08:15 PM
cdiddy14
Oct 18, 2003 03:32 PM
ten_30
Jan 28, 2002 04:58 AM
b18c5T
Jan 22, 2002 10:13 AM
