exhaust manifold smoking
Old Aug 9, 2007 | 02:48 PM
garageEF's Avatar
Default exhaust manifold smoking
alright im stumped....my valve cover seal was leaking oil all over my exhaust heat shield but i have since replaced it. it no longer leaks any oil. i de-greased the motor and its spotless...but my manifold still smokes a little...i cant identify the smell....but it doesnt smell like oil and the smoke is light.... any opinions will help me solve this problem
Old Aug 9, 2007 | 03:02 PM
abnaasefmb's Avatar
Default Re: exhaust manifold smoking (garageEF)
Here is my technical analysis of this problem: it burning off crap, give it a couple days.
Old Aug 9, 2007 | 03:23 PM
garageEF's Avatar
Default Re: exhaust manifold smoking (abnaasefmb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb &raquo;</TD></TR><TR><TD CLASS="quote">Here is my technical analysis of this problem: it burning off crap, give it a couple days. </TD></TR></TABLE>
i considered this....but most people said it should burn off in a few minutes.
idk...thats probably what it is, ill give it a few days and see.
Old Aug 9, 2007 | 04:27 PM
CoolRedXylophone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garageEF &raquo;</TD></TR><TR><TD CLASS="quote">alright im stumped....my valve cover seal was leaking oil all over my exhaust heat shield but i have since replaced it. it no longer leaks any oil. i de-greased the motor and its spotless...but my manifold still smokes a little...i cant identify the smell....but it doesnt smell like oil and the smoke is light.... any opinions will help me solve this problem </TD></TR></TABLE>
when i replaced my manifold the same thing happened, turned out to be the new ring gasket connecting the downpipe to the manifold. it went away after a day or two. just the gasket getting broken in i guess
dont know if this is whats going on with you but sounds similar
Old Aug 9, 2007 | 05:44 PM
janz3n's Avatar
Default Re: exhaust manifold smoking (CoolRedXylophone)
crap on the manifold should only smoke for a few minutes.. not days.
Old Aug 9, 2007 | 08:56 PM
Default Re: exhaust manifold smoking (janz3n)
Mine lasted 2 days.
Old Aug 9, 2007 | 09:36 PM
garageEF's Avatar
Default Re: exhaust manifold smoking ("Crise*One")
found the problem....oil pan gasket leaking on the header pipe...i'll fix it tomorrow
MHaz1701
Jan 25, 2018 07:39 PM
gt30rintegra
Sep 15, 2008 12:04 AM
em1si
Nov 28, 2006 05:15 PM
hybrid1990crx
10
Aug 3, 2005 10:38 PM
geldingmakr
Oct 6, 2004 03:58 PM
