over heating just rebuilt
Old Aug 9, 2007 | 02:35 PM
PBsTREETracer's Avatar
Default over heating just rebuilt
i have a b18a1 ls. it seems that it was overheating because of the thermostat so i changed it but it still over heats..i have new everything pretty much..water pump etc..i just got the bore done less than 200 miles ago so i dont think its the block and i have a brand new head gasket. when i ride with the ehat on full the car doesnt overheat anymore? do you think this air in my lines..when the car sits at idle the car doesnt over heat but after driving for like 25 min then it will get hot. please help thank you what are some other factors i should look at
Old Aug 9, 2007 | 03:42 PM
1700anddroping's Avatar
Default Re: over heating just rebuilt (PBsTREETracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PBsTREETracer &raquo;</TD></TR><TR><TD CLASS="quote">i have a b18a1 ls. it seems that it was overheating because of the thermostat so i changed it but it still over heats..i have new everything pretty much..water pump etc..i just got the bore done less than 200 miles ago so i dont think its the block and i have a brand new head gasket. when i ride with the ehat on full the car doesnt overheat anymore? do you think this air in my lines..when the car sits at idle the car doesnt over heat but after driving for like 25 min then it will get hot. please help thank you what are some other factors i should look at</TD></TR></TABLE>
what radiator are you running and in what car....but it sounds like your rad.
Old Aug 9, 2007 | 04:42 PM
idk what radiator i have in my 93 civic but which one should i go with for a turbo setup
Old Aug 9, 2007 | 05:49 PM
Default Re: (PBsTREETracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PBsTREETracer &raquo;</TD></TR><TR><TD CLASS="quote">idk what radiator i have in my 93 civic but which one should i go with for a turbo setup</TD></TR></TABLE>
there are several options.but most definitely go with a dual core rad.
Old Aug 10, 2007 | 07:37 AM
dohcdelsol93's Avatar
Default Re: (1700anddroping)
dual core radiator definatly.
There is probably still some air in your coolant system.
After I built my engine it took a little while to work all the air out.
Old Aug 10, 2007 | 06:34 PM
HatchSpeeD's Avatar
Check to see if the fan is kicking on. Jump the switch (the plug on the thermostat housing). If not, check fuse, then switch, & fan motor.
Old Aug 12, 2007 | 06:36 AM
Default Re: (HatchSpeeD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchSpeeD &raquo;</TD></TR><TR><TD CLASS="quote">Check to see if the fan is kicking on. Jump the switch (the plug on the thermostat housing). If not, check fuse, then switch, & fan motor. </TD></TR></TABLE>
ditto...just forgot to say it.also check to see if you have the fan wired BACKWARDS.it would be pulling heat off the motor and pulling it thru the rad.i have seen this and just shook my head.....
Old Aug 12, 2007 | 09:13 AM
thanks for the help guys my drunk mech. would do something liek put a backward fan on it lol
Old Aug 12, 2007 | 01:43 PM
HatchSpeeD's Avatar
If it's the oem radiator fan, i don't see how it can be backwards...It only plugs in one way.
djxtreme808
Jul 15, 2010 08:29 PM
dunchan1
Classic Hondas
Jun 24, 2008 03:55 AM
zccr-xsi
27
Mar 19, 2006 09:32 PM
