brake conversion
just look around on HT youll find a set you could even go to the sponsor section. i know there is a few good deals on brake conversions and even some itr stuff which is a ton better
go to the junkyard and ask for: 88-00 civic or 90-01 integra trailing arms w/ rear disc calipers on 9.4" rear rotors, they are all interchangable. *you'll need the appropriate e-brake cable for your 94 civic sedan, a non-abs rear disc valve proportioner, and a brake lines from the rear disc since the drum lines won't work. check honda-tech marketplace, plenty of rear disc conversions.
Modified by roastbeefrichie at 4:11 AM 8/12/2007
mynameizstitch
10
Dec 13, 2009 03:06 PM
WestSideRain
Apr 13, 2009 08:02 AM
