1995 Civic LX: A/C recharge hose doesn't fit charger port
Old Aug 9, 2007 | 12:39 PM
xunkn0vvnx's Avatar
Default 1995 Civic LX: A/C recharge hose doesn't fit charger port
A/C Recharge Hose
Refill the low pressure black side right?
For some reason it doesn't fit or stay on, AC just leaks out when I try to connect the hose
Modified by xunkn0vvnx at 3:42 PM 8/9/2007
Old Aug 9, 2007 | 12:43 PM
hatchling37's Avatar
Default Re: 1995 Civic LX: A/C recharge hose doesn't fit charger port (xunkn0vvnx)
You're sure your hose is for R134a? That's really the only thing that I can think of... You are correct in using the port with the cap with the "L" on it.
Old Aug 9, 2007 | 02:43 PM
xunkn0vvnx's Avatar
Default Re: 1995 Civic LX: A/C recharge hose doesn't fit charger port (hatchling37)
Yeah I'm positive its for R134a, and I would refill the top black hose right?
Old Aug 9, 2007 | 02:45 PM
sageuvagony's Avatar
You have the connections for a R12 not R134. You need to buy a retrofit kit. Mine cost like 10 bucks..
All the kit is really is 2 adapters. You screw on the adapters. Once you do, now you can just "clip" the R134 hose.
The adapters are what you need.
Old Aug 9, 2007 | 05:02 PM
Just took this picture of my car for you. If your car is a 95, I'm not sure why your system has a R12 fitting.
The adapters simply screw on and that's it. Takes 12 seconds to install.
Old Aug 9, 2007 | 05:37 PM
Hippo393's Avatar
Default Re: (sageuvagony)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sageuvagony &raquo;</TD></TR><TR><TD CLASS="quote">If your car is a 95, I'm not sure why your system has a R12 fitting.</TD></TR></TABLE>
x2! Or could your car possibly be Canadian?
Old Aug 9, 2007 | 05:51 PM
TypeRobert's Avatar
Default Re: (Hippo393)
hey man i got a cd player for cheap PM me
Old Aug 9, 2007 | 06:36 PM
fast forward driver's Avatar
Default Re: (TypeRobert)
the lines on 92 and early 93's where still r-12 which is what op has ,r-134a is a larger port , like already said, you just need a retrofit kit availible at any parts store or you can pay up for r-12 about $65 a 12oz can around here , I'd add the fitting's , dont put in to much 134 as it has a runs at higher pressure's
the car must have had lines changed somewhere down the line , also you want to add the freon to the line going to the compressor which is the "suction " side or low pressure side
Old Aug 9, 2007 | 09:33 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeRobert &raquo;</TD></TR><TR><TD CLASS="quote">hey man i got a cd player for cheap PM me</TD></TR></TABLE>
That's true also. Buying a CD player will make that hose fit Name:  bloated.gif
Old Aug 11, 2007 | 09:36 AM
TypeRobert's Avatar
Size:  1.3 KB</TD></TR></TABLE>
i was responding to his signature you fukhead
HndaOwner
Mar 8, 2016 04:14 PM
nihkon
11
Sep 13, 2009 05:54 PM
DaX
Nov 23, 2005 08:45 PM
spaceman
May 9, 2004 08:46 PM
