Questions about Auto Tranny Fllush for 1995 Accord
Old Aug 9, 2007 | 12:38 PM
m1ndless's Avatar
* B A N N E D *
Default Questions about Auto Tranny Fllush for 1995 Accord
I need to drain and refill it 3 times, right?
How many quarts per dreain and refil?
Where do I add the new fluid?
Where is the bolt to drain the fluid?
THANKS!!
Old Aug 9, 2007 | 12:59 PM
tsiah's Avatar
go buy a service manual
there's a plug on the bottom of the trans, passenger side. use a 3/8" ratchet to remove it. clean the gunk off the plug, refill with honda ATF Z-1 through the dipstick hole (long black funnel from walmart is the best I've found for this)
drive the car a few miles, drain and fill again to your hearts desire...
I did 2 drain and fills on my sisters 94....fluid came out pretty clean on the 2nd drain, so I didnt go for a 3rd. fluid is still clean on the dipstick 6k miles later...
Old Aug 9, 2007 | 01:21 PM
methodical's Avatar
Default Re: (tsiah)
yea ^^^ what he said. i did this a few months ago and i could really tell a difference. the tranny shifts a lot smoother.
Old Aug 9, 2007 | 02:29 PM
m1ndless's Avatar
* B A N N E D *
Default Re: (methodical)
I really need to do it, my tranny doesnt want to shift sometimes, it will go up high in the rpms, then do a hard shift.
No matter how slow I drive, and accelerate smoothly, I can still feel that shift, I think that means I better freakin flush it.
How many quarts per drain and refil? 3-4 right?
Its the dipstick thats kinda hard to get to on the front/passenger side of the engine, its yellow or orange, right?
Old Aug 9, 2007 | 02:52 PM
Homesickelian's Avatar
Default Re: (m1ndless)
you'll always feel the shift, and I'm glad I can. The 5th gen accords have somewhat rough automatic shifts and they're known for it. Doesn't mean it's bad quality, it's just how they are. I'm not saying you don't need a change.
Have you looked at the color of the fluid? It should be a somewhat transparent red/rose color. Look for brown color and flakes/debris which will tell you it really needs a fluid change.
Also, read the dipstick when it's warmed up, unlike motor oil, but yes it's down there by the bottom of the tranny.
Modified by Homesickelian at 4:23 PM 8/9/2007
Old Aug 9, 2007 | 03:48 PM
Charri's Avatar
Default Re: (Homesickelian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Homesickelian &raquo;</TD></TR><TR><TD CLASS="quote">you'll always feel the shift, and I'm glad I can. The 5th gen accords have somewhat rough automatic shifts and they're known for it. Doesn't mean it's bad quality, it's just how they are. I'm not saying you don't need a change.
Modified by Homesickelian at 4:23 PM 8/9/2007</TD></TR></TABLE>
caution for it can burn and be very painful
Old Aug 9, 2007 | 05:15 PM
Default Re: (Charri)
heh yeah, it doesn't help that it's right by the radiator hose and ****. Best to drive the car then let it cool down for 5 or 10 mins maybe. At least you'll only sear your hand off instead of your whole arm.
Old Aug 9, 2007 | 06:53 PM
m1ndless's Avatar
* B A N N E D *
I checked my fluid, it has a little bit of a burnt smell to it, its not bad at all, barley noticable, its a reddish brown color.. I think I should change it, right?'
Also, no one has answered it yet,
HOW MANY QUARTS PER REFILL?
Old Aug 9, 2007 | 07:35 PM
AJ06's Avatar
this reminds me... i need to do this shiitttss
Old Aug 22, 2007 | 03:01 PM
m1ndless's Avatar
* B A N N E D *
Default Re: (AJ06)
How many quarts per drain and refil do I need - 4 or 5?
Old Aug 22, 2007 | 03:03 PM
TheMuffinMan's Avatar
He knows where you live!
i believe the tranny holds 3.5
Old Aug 22, 2007 | 03:11 PM
el dominicano 24's Avatar
Default Re: Questions about Auto Tranny Fllush for 1995 Accord (m1ndless)
i need to also get on a trany flush this weekend ppl tell me u fell the difference when done
Old Aug 22, 2007 | 07:45 PM
JimBlake's Avatar
Default Re: Questions about Auto Tranny Fllush for 1995 Accord (el dominicano 24)
The 4-cyl auto tranny holds over 6 quarts but only about 2.5 drains out. That's the reason for multiple drain/fills. M1ndless says his smells burnt, but for the rest of you... if the first drain comes out clean & doesn't smell, I wouldn't bother doing more.
Old Aug 25, 2007 | 04:34 PM
m1ndless's Avatar
* B A N N E D *
Default Re: Questions about Auto Tranny Fllush for 1995 Accord (JimBlake)
Mine doesnt really smell that burnt, it looks like newer oil, its not black or anything..
So for 2 drain and refils, I should get 6 quarts total?
Old Aug 25, 2007 | 06:33 PM
Secret Chimp's Avatar
Call around your local Honda dealers. I ended up getting a whole case of Z1 for $50, when another dealer could have cost me $112. I did a change on my trans earlier this year and the fluid is brown again thanks to either its age or the heat, so I'm glad I have some on hand still.
Old Aug 25, 2007 | 06:40 PM
BLKFLSH's Avatar
Yes, 6quarts will do two changes. If the fluid is brown, I would do 2 changes. Happy Hondaing.
Old Aug 26, 2007 | 09:11 AM
JimBlake's Avatar
Default Re: Questions about Auto Tranny Fllush for 1995 Accord (BLKFLSH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLKFLSH &raquo;</TD></TR><TR><TD CLASS="quote">Yes, 6quarts will do two changes. If the fluid is brown, I would do 2 changes. Happy Hondaing. </TD></TR></TABLE>If it's brown, make sure you look at what drains out the 2nd time. Then plan your future changes on that. Since so much stays behind when you drain, there will ALWAYS be some residual left over. Maybe plan your next change for 10k miles or even sooner. You will want to know how soon it gets dirty again.
Old Aug 28, 2007 | 08:50 AM
I just did another change on my car this morning after putting maybe 8,000 miles on it after the first one. The fluid still had a slight rose tinge to it, but the magnetic plug had nasty BLACK sludge on it instead of silver stuff from the first time! If your fluid doesn't look red at all when you drain it, do another drain around the same time you do an oil change.
I may get a smaller tube for my manual suction pump and try and scrounge out some of the sludge on the bottom of the pan when I do another change around the end of the year just to be safe.
Old Aug 28, 2007 | 02:10 PM
m1ndless's Avatar
* B A N N E D *
Default Re: Questions about Auto Tranny Fllush for 1995 Accord (Secret Chimp)
Its a really clearish brown, not black or stinky really.. so 2 drains should be good? I will go ahead and purchase some ATF fluid then, thanks!
Old Aug 29, 2007 | 05:29 PM
not sure if you know but make sure you get Honda ATF, not anything else. Honda transmissions seem to be pretty picky so get the right stuff...
Old Aug 29, 2007 | 05:54 PM
m1ndless's Avatar
* B A N N E D *
Default Re: Questions about Auto Tranny Fllush for 1995 Accord (Homesickelian)
ATF-Z1 is the genuine stuff, right?
Old Aug 29, 2007 | 06:05 PM
BLKFLSH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m1ndless &raquo;</TD></TR><TR><TD CLASS="quote">ATF-Z1 is the genuine stuff, right? </TD></TR></TABLE>
I hate to quote a Hyundai commercial, but DUH!
Projectsonic
13
Sep 19, 2012 10:30 AM
alexdc03
Mar 26, 2012 04:40 PM
Brum_RU
Mar 15, 2008 08:27 PM
m1ndless
Nov 12, 2007 05:38 PM
slowd16z6
Dec 12, 2003 01:51 PM
