Clutch Clatter Noise, is it Normal?
My 02 Type 2 has about 115K miles on the stock clutch. I notice that there's a "clatter" when the clutch pedal is not in. It makes a sound similar to valves tapping ALOT.
When I press the clutch pedal in, it goes away. Is this normal noise?
Note: It was noticeable as I was in a small garage like area, with the window down. Otherwise, I'd have never noticed the difference in noise between clutch in/clutch out. It's not noticeable under normal driving.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2fasttypes »</TD></TR><TR><TD CLASS="quote">am sure it is ur just letting out the clutch a lil too much to the point where ur gonna stall out mine does dat too and mines an 05 type-s w/43k</TD></TR></TABLE>
The clatter I hear is with the tranny in neutral, not while in gear.
SOHC_Brian
Aug 23, 2004 09:58 AM
