accord h22a7 euro-r turbo problem (ecu ) idling
Old Aug 9, 2007 | 11:25 AM
lil_williams's Avatar
Default accord h22a7 euro-r turbo problem (ecu ) idling
hi guys
i have a problem
i installed a turbokit on my h22a7 euro type-r
i hade to change my stock ecu
i now runnin the p28 with crome
idle is to high 1600 , aint no changing always 1600
i hade to change the iacv-valve to 2 wire
i dont know how to diseable this problem
that the idle is 1000 or less
thx william
Old Aug 10, 2007 | 07:14 AM
Default Re: accord h22a7 euro-r turbo problem (ecu ) idling (lil_williams)
can somebody help by my problem ?
Old Aug 10, 2007 | 07:58 AM
GhostAccord's Avatar
Default Re: accord h22a7 euro-r turbo problem (lil_williams)
1. Check for vacuum leaks, Throttle body gasket, vacuum lines, intake to engine gasket.
2. Do you know what the base idle was set to in Crome? If it's set at 1600rpm in Crome there isn't much you can do without reprograming it.
3. Is the new 2 wire IACV working properly?
Try this: If you take your intake piping/CAI/SRI off and look inside your throttle body you should see 2 holes on the left side. The one on the top is for the IACV and the one on the bottom is for the FITV. With your car running put your thumb/finger over the holes one at a time. Does plugging either of them drop your idle? If it does then there is something wrong with the corresponding valve.
Old Aug 10, 2007 | 08:12 AM
Default Re: accord h22a7 euro-r turbo problem (GhostAccord)
i checked all vacumlines and gaskets
the iacv is not installed on the intake manifold ( its just for throwing no code on the ecu)
i have to fix me a plate for the new iacv
maybe thats the problem ?
in crome the idle was set to 750 but it runs more than 1700 rpm
Old Aug 10, 2007 | 09:34 AM
What do you have in it's place on the manifold right now? Do you have the three wire IACV installed with out being wired up? If you do that could be your problem. The 3 wire IACV that is on there will stay in the open position without a signal from the ECU.
Old Aug 10, 2007 | 09:52 AM
yes the 3 wire is still installed in the intake manifold and i cut all the lines
should i take it out and replace it with the the 2 wire ?
does it fit plug and play or do i have to get my self a plate for install ?
thx william
Old Aug 10, 2007 | 01:16 PM
raceACCORDingly's Avatar
how did you re-wire the 3 - 2 wires?
blacktrax.net sells a 3 - 2 wire iacv adapter plate.
Old Aug 11, 2007 | 02:39 AM
Default Re: (raceACCORDingly)
i friend of mine did it , i dont know
kanashibari
Nov 14, 2011 03:48 AM
integrainside
Mar 16, 2010 09:14 PM
crxfreak1117
Sep 8, 2007 07:05 PM
TurboDX
Oct 23, 2002 07:18 AM
QWKPHKR
Oct 8, 2002 06:37 PM
