H22 Turbo (20psi)520hp - RPM Kickdown (no redline while boosting)
Old Aug 9, 2007 | 10:46 AM
Mfoehrkolb's Avatar
Default H22 Turbo (20psi)520hp - RPM Kickdown (no redline while boosting)
Fully built H22 Turbo (20psi)
Garret GT40
Tial 50mm bov
Fiber-Tuned Intake
2 Fuel Pumps
RC1000cc Injectors
Hondata s300
--The problem im having is when spooling to full boost in 3rd gear, when i hit around 18.9psi around 6k rpms. The motor kicks the rpm's down, and the check engine light comes on for a split second. 1st, and 2nd i can red line and spool what i can no problems, just once im in 3rd and 4th i get that problem with the rpm's.
Modified by Mfoehrkolb at 2:56 PM 8/9/2007
Old Aug 9, 2007 | 11:08 AM
boots89's Avatar
Default Re: H22 Turbo (Mfoehrkolb)
are you running the s300 as a boost controler?
Old Aug 9, 2007 | 01:30 PM
Mfoehrkolb's Avatar
Default Re: H22 Turbo (boots89)
s300 isnt used as boost controller, my boost controller is a 'TurboSmart E2 Boost Controller'
Old Aug 9, 2007 | 07:34 PM
89s1's Avatar
more load in those gears. Is it possible that boost creep is causing a software fuel cut?
Old Aug 10, 2007 | 06:30 AM
andoxviii's Avatar
God damn....that setup looks deadly. Very nice
good luck with your issue. Free bump
Old Aug 11, 2007 | 01:11 PM
Mfoehrkolb's Avatar
Default Re: H22 Turbo (89s1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89s1 &raquo;</TD></TR><TR><TD CLASS="quote">more load in those gears. Is it possible that boost creep is causing a software fuel cut?</TD></TR></TABLE>
i check, couple of people in the induction section of the forums, are saying they had similar problems. but was caused from the rotar button.
Mfoehrkolb's Avatar
Default Re: (andoxviii)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andoxviii &raquo;</TD></TR><TR><TD CLASS="quote">God damn....that setup looks deadly. Very nice
good luck with your issue. Free bump</TD></TR></TABLE>
haha thanks man, it is pretty deadly
Old Aug 11, 2007 | 03:59 PM
B20Frankenstein's Avatar
Default Re: (Mfoehrkolb)
Free Bump - car is fire
Old Aug 12, 2007 | 01:57 AM
xXSilentScreamXx's Avatar
Default Re: (B20Frankenstein)
how much was the full build?
Old Aug 12, 2007 | 07:33 AM
non-VTEC's Avatar
sounds like it might be a boost cut issue tuned in the ECU/hondata.
have your tuner check the tune over.........
Old Aug 12, 2007 | 06:35 PM
4g hatch's Avatar
what intake and tb is that. free bump here also
Old Aug 13, 2007 | 09:09 AM
hitekper4mance's Avatar
Default Re: (4g hatch)
ish does look sick.
Old Aug 16, 2007 | 11:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g hatch &raquo;</TD></TR><TR><TD CLASS="quote">what intake and tb is that. free bump here also</TD></TR></TABLE>
intake is Fiber Tuned --- CF intake --- 1 of 2 in the world Limited Edition
Old Aug 18, 2007 | 06:10 PM
speedworksengineering's Avatar
what clutch are you using sir? I turboed my h22 also and I got the RPS clutch. Dunno if it can hold the torque though when i increase the boost after methanol injection.
Old Aug 19, 2007 | 03:41 PM
Mfoehrkolb's Avatar
Default Re: (speedworksengineering)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedworksengineering &raquo;</TD></TR><TR><TD CLASS="quote">what clutch are you using sir? I turboed my h22 also and I got the RPS clutch. Dunno if it can hold the torque though when i increase the boost after methanol injection.</TD></TR></TABLE>
using a ACT Max Xtreme clutch kit, its a full race application. i got basicly the best in the car.
Old Aug 20, 2007 | 04:55 AM
thanks hopefully my clutch holds I still plan on driving my car in the streets once in awhile. how much for the intake manifold? I cut up my EK also. Although yours looks better. H22 powah!
Old Aug 20, 2007 | 12:02 PM
Mfoehrkolb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedworksengineering &raquo;</TD></TR><TR><TD CLASS="quote">thanks hopefully my clutch holds I still plan on driving my car in the streets once in awhile. how much for the intake manifold? I cut up my EK also. Although yours looks better. H22 powah!</TD></TR></TABLE>
--- the intake manifold runs about 3,500. when i built the car, it was 1 of 2 in the world. so good luck getting one.
ImPuLsIvE
Jul 13, 2008 02:54 PM
Mfoehrkolb
Aug 12, 2007 05:04 PM
Speedra500
Jan 31, 2005 12:53 PM
