Pistons Questions
Old Aug 9, 2007 | 09:15 AM
girliehonda's Avatar
Default Pistons Questions
I debating on choosing Mizumo Auto Parts High Dome LS pistons on Ebay $124.00 or buy Race Spec ITR replica pistons?
My dad said if the Mizumo High Dome LS piston should fit perfectly then shaving off alittle of the stock ls rods in order to fit the RS pistons. What do you guys think?
What kind of gas mileage would those compression ratio put on the car?
Setup is b16 head on b18b ls block.
Old Aug 9, 2007 | 03:25 PM
ToeJam's Avatar
Default Re: Pistons Questions (girliehonda)
your set up is called an ls-vtec. there are a lot of write-ups on it.
use the search and im sure you will find out what pistons will fit and yield you the CR you want.
FYI: with b16 pistons (pr3 or p30) you dont have to do any modding to the rods.
Good luck with the build.
Old Aug 10, 2007 | 04:08 AM
Default Re: Pistons Questions (ToeJam)
thanks
jhammond_82
Jul 15, 2009 04:44 PM
almostjdmeg
Jul 26, 2008 12:17 PM
dcdcdc
Mar 20, 2008 11:28 PM
vtec_yosh
Aug 28, 2004 07:44 PM
One8Hatch
Oct 9, 2001 05:48 AM
