need help!!
cant rev over 3500rpm, still has power to wheels when the clutch is depressed, doesnt shift unless it is moving or the car is turned off, and if you press the gas pedal more than about 1/4 in then it tries to die.
throwin 2 codes, map sensor and cyp sensor
the throttle body is leaking a little, could this be part of the problem with the map and revin?
just put in a jdm b16, b16a2 head, gsr tranny.
has some minor bolt ons, gsr cams, turbo, etc. etc.
any suggestions would be appreciated.
a turbo is a minor bolt on!?!? a leak from the tb would def have something to do with your problems! and if you already have a cel, i would work on fixing what you already know is wrong. then see how your car runs.
kechup2eg6
Aug 10, 2005 07:47 PM
