Stock Sleeves On A B18C1 GSR Engine
Old Aug 9, 2007 | 08:09 AM
hatchin's Avatar
Default Stock Sleeves On A B18C1 GSR Engine
I was wondering how much power the stock sleeves will hold on a B18C1 GSR engine. I am building one with 11.5:1 Compression, Crower Stage 2 cams, a B16 head with porting, and a 100 shot direct port nitrous (should produce about 300 to the wheels on the bottle) and I will not use the nitrous untill 2nd gear. Thanks for any input.
Old Aug 9, 2007 | 04:26 PM
89s1's Avatar
Default Re: Stock Sleeves On A B18C1 GSR Engine (hatchin)
it all comes down to the tune
to be honest, how much my sleeves will take would be the last thing on my mind everytime i sprayed a 100 shot tho
Old Aug 9, 2007 | 11:32 PM
Rd91SiB18ls's Avatar
I've sprayed a 75 sho dry on a ls motor and a type r motor,
both motors are still alive with stock bottems. Just retard the
timing and increase the fuel pressure.
Old Nov 20, 2007 | 07:31 AM
hatchin's Avatar
I will build it and get a good tune on it and all should be well then. Thanks
Old Nov 20, 2007 | 08:20 PM
mx621's Avatar
people have made 650whp on stock sleeves. oem sleeves are much stronger than people think. poor tuning is the reason for most sleeve failures, within this hp threshold.
frankie99si
Aug 28, 2009 03:22 AM
mo0cow
Jan 28, 2006 08:46 PM
JuanK20
Nov 30, 2004 06:41 PM
mrcivicsi2k
May 10, 2004 07:29 AM
tweekerz
Jun 25, 2001 07:39 AM
