95 Died while Driving and Won't Start
Old Aug 9, 2007 | 06:29 AM
Pure_Lude's Avatar
Default 95 Died while Driving and Won't Start
Alright so I have a 95 srv 2.2l vtec 5spd and was driving home from my friends house when the rpms dropped and stalled out on me. I tried to start it but no go, it tries to turn over but it never happens, well it happened once and lasted about 10 seconds then died out again.
I am not getting a spark, or so i'm told, and I have tried changing the distributor, ignition coil, main relay, and my battery is good. None of these have worked.
What else am I lookin at here?
Old Aug 9, 2007 | 06:34 AM
carnot's Avatar
Default Re: 95 Died while Driving and Won't Start (Pure_Lude)
are you sure you are getting fuel? can you smell gas after trying to start the car?
Old Aug 9, 2007 | 06:43 AM
Pure_Lude's Avatar
Default Re: 95 Died while Driving and Won't Start (carnot)
What would be an easy way for checking to see if i'm getting fuel? Just smell for gas?
Old Aug 9, 2007 | 09:23 PM
Fongman's Avatar
alot of honda seems to have bad main relay. this relay control fuel, but if you don't spark, this can be your control module inside the dissy.
Old Aug 9, 2007 | 09:40 PM
lude_si_95's Avatar
Default Re: 95 Died while Driving and Won't Start (Fongman)
check to see if your timing belt snapped this same thing happened to me, not a fun fix but it happens to the best of us
Old Aug 10, 2007 | 01:24 AM
jdmh22a1's Avatar
check ur ign switch
Old Aug 10, 2007 | 12:56 PM
snzh22's Avatar
Default Re: (jdmh22a1)
is ur fuel pump kicking? to test, listen for it when u put ur key in the on position. or u can listen at the gas cap.
Old Aug 10, 2007 | 03:57 PM
JSpekBB4's Avatar
my 5th gen is doing this right now, my god father owns a shop I brought it too and her messed with the control module inside the dizzy and the car started again and runs and turns off and runs and turns off but after a while of running it will just die out again... so I'm replacing the module... I'll let you know tomorrow how that works... but I'm getting mine form advnaced for 81
Old Aug 10, 2007 | 05:08 PM
SKDRCR's Avatar
Default Re: (JSpekBB4)
I'd agree, it sounds like the symptoms of an ignitor going bad.
Old Aug 11, 2007 | 11:38 AM
preludeboybmw's Avatar
ignitor or timing bet ....i know both happend to me
Championship
Nov 25, 2010 05:36 PM
samvilay
Oct 31, 2009 02:46 PM
yahboyryan
Mar 17, 2008 05:41 PM
Pure_Lude
Mar 10, 2007 08:19 AM
.Noah Fecks
11
Aug 9, 2003 08:06 PM
