temp gauge in cluster fluctuating
Old Aug 9, 2007 | 05:20 AM
mr_gs-r's Avatar
Default temp gauge in cluster fluctuating
The past couple of days i've noticed that when i take it to the upper rpm range the temp gauge will peg to the cold mark, then when i shift it goes back to normal operating temp, same thing when i rev to the top of the next gear.
I have blead the coolant sytem a couple of times but no luck with that fixing it. I recently removed the IACV to clean it, i thought that might have let some air get in or something. I'm stupmed, tried searching but no luck finding anything.
Old Aug 9, 2007 | 06:35 AM
cmdr430's Avatar
Default Re: temp gauge in cluster fluctuating (mr_gs-r)
https://honda-tech.com/zerothread?id=2003313
i have changed the thermostat and it seems to be working fine, i am also going to change the temp sending unit....
Old Aug 9, 2007 | 08:20 AM
mr_gs-r's Avatar
Default Re: temp gauge in cluster fluctuating (cmdr430)
thanks for the link, its worth a try i guess. i'm pretty sure its not the sender.
Also let me add that it consistently does this, ie. every shift if i rev it high.
Old Aug 9, 2007 | 08:59 AM
TPB's Avatar
TPB
What procedure do you use to bleed the system? Sounds like you still may have air in there.
Old Aug 9, 2007 | 09:39 AM
teg01type-r's Avatar
Default Re: temp gauge in cluster fluctuating (TPB)
I would love to know what the problem with this is, as mine does the same exact thing.
Old Aug 9, 2007 | 09:46 AM
mr_gs-r's Avatar
i leave the cap off and crank the engine, let it reach full operating temp and let the fans kick on, top it off and put the cap back on. I think i forgot to slide the temp comtrol slider to the hot side though...dont know if that would make a difference here.
Old Aug 10, 2007 | 04:48 AM
mr_gs-r's Avatar
blead the coolant system again last night, the problem is still there but now the gauge only moves down 1/4 to 3/8's of an inch at high rpm's... getting closer lol.
Old Aug 12, 2007 | 10:37 AM
mr_gs-r's Avatar
found the cause, thermostat apparantley was getting ready to fail. I replaced it and it solved the problem. Hope this helps anyone that has the same problem inthe future.
the soL that could
Mar 14, 2009 06:20 PM
bigislandc2
Jan 4, 2008 07:20 PM
B6teen
10
Dec 23, 2006 05:55 PM
Sir_Phobos
Dec 7, 2002 08:45 AM
