How do you measure valve guide bore?
My exhaust valves feel a bit too wobbly, so I'm trying to determine of the valve-to-guide clearance is out of spec. The valves check out fine, but I'm not sure how to measure the guide bores. Some sort of tiny dial bore gauge or something?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pomansouth01 »</TD></TR><TR><TD CLASS="quote">take it to a machine shop, they will have things that look like dowels that are tapered slightly and are certain diameters....they will check it out for you...</TD></TR></TABLE>
Hmmm... What are these things called? I wonder if I can buy just the one size I need.
Hole (bore) gauges on ebay:
http://cgi.ebay.com/4-PC-PRECI...wItem
I think pomansouth01 is referring to a tapered pilot, which is a good way to measure the minimum size of the bore. You'll want to measure the maximum size, though, to indicate wear. You'll need a good micrometer to go with the bore gauge.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stumpyf4 »</TD></TR><TR><TD CLASS="quote">Use a pin gauge set... like feeler gauges but for holes.
http://www.micron-inc.com/gage.htm
thats what you want.
You can also use a split ball gauge (small hole/small bore gauge), which will be much more accurate, and is expandable so that you get a good fit, like a mic or feeler gauge.
A small set (usually 4 or 5 different ones) can run you about 80 bucks, but I would not use this if its a one time only deal, since you really should use a micrometer with this as well.
trustbuddy
May 12, 2005 02:43 PM
vtec.dc2
Apr 26, 2005 07:57 AM
redcrx187
19
Oct 14, 2004 07:29 PM
