injectors - couple of Qs
Old Jun 11, 2002 | 11:19 PM
tinkerbell's Avatar
Default injectors - couple of Qs
what injectors were used on the 88-91 B20A preludes?
what injectors were used on the 92-96 H22A preludes?
what happens if i fit larger injectors and run the stock computer,
thanks,
t..
Old Jun 12, 2002 | 01:05 AM
Giuseppe's Avatar
Default Re: injectors - couple of Qs (tinkerbell)
peak and hold 240cc
peak and hold 345cc
you would have a hard time at idle if you dont turn down the fuel pressures
youd need a fully adjustable fuel pressure regulator..
and youd definitely run rich!
Old Jun 12, 2002 | 02:55 AM
tinkerbell's Avatar
Default Re: injectors - couple of Qs (Giuseppe)
peak and hold 345cc
so if i were to go 2.0VTEC with a B20B block and B16A head,
i could fit teh 345cc injectors, use stock ECU, run a adj FPR and would i be able to tune the fuel map with a FC?
does this sound right?
does the V-AFC have this sort of range practically?
or would there be a better way eg Hondata?
thanks,
t..
Old Jun 12, 2002 | 03:02 AM
Buckkaaaa!!'s Avatar
New User
HONDATA!!
Old Jun 12, 2002 | 05:03 AM
YeuEmMaiMai's Avatar
Default Re: injectors - couple of Qs (preludeboy)
i'll second that
sikefcrx89
Mar 13, 2019 01:43 PM
96redgsr
Jul 21, 2004 09:46 PM
SpeedMonkeyRacing
Sep 7, 2002 08:13 AM
azn98R
Mar 6, 2002 08:03 AM
smoothludey2
Sep 6, 2001 06:48 PM
