Gsr ek help
Whats up I have a 98 dx 5 speed body i just recently swapped a b18c (obd1) gsr motor and tranny into it.. I used the stock sohc (obd2) harness and just converted the plugs to obd1 (dizzy, alternator, injectors and iacv plug)... since the motor is obd1 and im using a jumper harness and running a p28.
Well the problem is it has no spark. the fuel pump comes on. and Only code it throws is 16 which i believe is injectors. I've gone over all my wiring and im %100 its correct i've done it many times.. but I'm at a loss It was getting spark yesterday and didnt even want to turn over it just cranks... any ideas?
if you said you checked your wiring over and its good then it might be your dizzy. if your not getting no spark, your dizzy coil might be bad or even the cap and rotor. check those out. or jsut get another dizzy from a friend and try it. i had the same problem before in my car.
good luck
good luck
hialeahzbg
Jul 27, 2009 08:38 PM
h22-hatch
Jul 2, 2007 01:56 PM
BoostedVtecGsr
Apr 30, 2007 08:49 PM
ef8sleepr
Feb 23, 2006 09:25 PM
