Where to buy - 1/8" NPTF aluminum weld bung?
I figure it would be cheaper than buying a tap I'll use once.. Anyone know where to get these? I need to put a bung on my intake mani for an AEM 3.5bar map sensor. The kit appears to come with a brass NPT-AN adapter, but that won't do me any good. Thanks!
ur talking about a little bung similar to an o2 bung except made out of aluminum and with 1/8" pipe tapped threads correct? i can whip one up in a few minutes if u want.
All that being said, it is not recommended to mount them directly on the manifold, they don't like the vibration. Mount it on the firewall and run a vacuum line to it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">All that being said, it is not recommended to mount them directly on the manifold, they don't like the vibration. Mount it on the firewall and run a vacuum line to it.</TD></TR></TABLE>
Well that explains why it comes with a NPT - AN adapter then. In that case I'll just tap the existing hole in the manifold for 3/8 NPT, and put a NPT - AN fitting in there, and run a hose to the remote-mounted sensor.
Thanks everyone for the help!
1sick4g63
Welding / Fabrication
Jun 29, 2013 05:43 AM
