15x7 & 16x7 TE-37 Question...
Old Jun 11, 2002 | 10:07 PM
kepani's Avatar
Default 15x7 & 16x7 TE-37 Question...
me if this has been discussed too many times.
i'm checking out some 15x7 & 16x7 te-37's fo' da R and was wondering if anyone has/had experience with these wheels and sizes.
i referred to the holy itrca.com wheel guide <http://www.itrca.com/faq/wheel_guide.asp>. very nice guide btw. however, i couldn't find an entry for the 15" te-37. i did find in the guide that the recommended offset for the 16" te-37 is 43mm.
i have two (2) major questions:
1. (short one) does anyone know a preferrable offset for the 15x7 te-37's for the type r?
2. (long one) i checked out the Mackin Industries Site and found that the 16x7 te-37's are available with a +42mm offset. then i looked at IPSRacing.com and found that they offer 16x7 te-37's with a +45mm offset. to top it off, the ITRCA Wheel Guide recommends a +43mm offset. which of the three are correct? are te-37's offered in 42mm, 43mm, & 45mm? and of the ones that volk racing does make, which offset is the best?
sorry if this post is confusing...i just wanna sort some of this confusion out and get me some rims! thanks!!!
Old Jun 11, 2002 | 10:14 PM
98R-1144's Avatar
Default Re: 15x7 & 16x7 TE-37 Question... (kepani)
i am running 15x7 +43 te-37's.. 205/50/15 tires. fits fine on stock suspension
Old Jun 11, 2002 | 10:19 PM
Hybrid ctr's Avatar
Default Re: 15x7 & 16x7 TE-37 Question... (98R-1144)
15x7 5x114.3 +43
16x7 5x114.3 +42
These are the correct offsets
HTH
Old Jun 11, 2002 | 10:22 PM
B2FiNiTY's Avatar
My dream wheels are 16x7 GM Te-37s /+43offset yumm....
Old Jun 11, 2002 | 10:26 PM
Hybrid ctr's Avatar
Default Re: 15x7 & 16x7 TE-37 Question... (Hybrid ctr)
16x7 5x114.3 +42
Old Jun 11, 2002 | 10:38 PM
kepani's Avatar
just to throw a money wrench in it all...do these sizes still apply if you get a coilover setup?
thanks B2, Hybrid ctr, & 98R-1144 for some confidence builders
kepani-who feel's the from fellow -techers...
Old Jun 11, 2002 | 10:41 PM
Hybrid ctr's Avatar
What do you mean, I don't understand your question???
Old Jun 11, 2002 | 10:45 PM
kepani's Avatar
from what i've heard and read, when you lower the car, you increase the chance of rubbing your fender or your wheel well. if i lower the car, will the wheel, for the same offset, likely rub the fender or wheel well? does that make sense?
Old Jun 11, 2002 | 10:59 PM
Hybrid ctr's Avatar
I'm sure you won't rub with +42/43 offset if you only lower your car 1" or so.
Phat Bastard's car is lowered 2" on +50 MF10's, he doesn't rub.
Tommy_Gunns's Avatar
I too would like to know if 15x7 wheels with +43 offset would fit on an ITR with lowered stance (say 1-2" lower than stock).
Old Jun 11, 2002 | 11:02 PM
Hybrid ctr's Avatar
Default Re: 15x7 & 16x7 TE-37 Question... (Tommy_Gunns)
The correct offset for the itr is +50.
Imagine offset this way, +50 will be nicely tucked in the wheel well, and +30 your car will look like a lowrider
Old Jun 11, 2002 | 11:11 PM
That's true for the stock rim (6" wide). But for a 7" wide rim, I think it would be different to make sure the rims clear the suspension arms or am I thinking wrong?
Old Jun 11, 2002 | 11:22 PM
ITRbroham's Avatar
shit post warrior
When I had my ITR I had 17x7 Advan Model 7 w/ +50 offset. They cleared the suspension arms ok. Hope that helps.
Old Jun 12, 2002 | 04:39 AM
Cosworth's Avatar
I know everyone says this all the time... but,
if you <u>don't</u> track or autoX, go with 16x7" rims w/ 215/45/16 tires. The handling is a lot crisper than with 15" combo. And, with Volk's, your 16" rims will only weigh a few pounds more... which to me is not a big deal for street application.
Old Jun 12, 2002 | 04:47 AM
SoCal ITR's Avatar
Default Re: 15x7 & 16x7 TE-37 Question... (Cosworth)
If I did get wheels, they would be 16x7 w/ 215/45 16 tires.
Old Jun 12, 2002 | 06:06 AM
Jon7's Avatar
Default Re: 15x7 & 16x7 TE-37 Question... (SoCal ITR)
I have 16x7 te-37s with 42mm offset and 215/45/-16s.
No rubbing, no problems.
Old Jun 12, 2002 | 06:24 AM
BryanSprinkel's Avatar
Fits fine. Just dont go show stunna low
Old Jun 12, 2002 | 08:46 AM
Anderson's Avatar
Default Re: 15x7 & 16x7 TE-37 Question... (B2FiNiTY)
Old Jun 12, 2002 | 09:34 AM
TakaIntegra's Avatar
Default Re: 15x7 & 16x7 TE-37 Question... (Anderson)
I want these
Old Jun 12, 2002 | 10:22 AM
ITRbroham's Avatar
shit post warrior
Default Re: 15x7 & 16x7 TE-37 Question... (TakaIntegra)
I want these
So do I
Old Jun 12, 2002 | 10:28 AM
Reid's Avatar
Global Moderator
Assuming the wheels are exactly the same except for offset,
+50 will have a wider track than +30.
Old Jun 12, 2002 | 10:59 AM
vwong's Avatar
Default Re: 15x7 & 16x7 TE-37 Question... (Reid)
It's the other way around. +30 will have a wider track than +50.
Old Jun 12, 2002 | 11:04 AM
vwong's Avatar
I want these
They're very nice, don't they? They look real good on my car. The wheels on the first pic look kinda dark 'cuz of the lighting.
[Modified by vwong, 10:49 PM 6/12/2002]
[Modified by vwong, 10:50 PM 6/12/2002]
[Modified by vwong, 8:58 AM 6/13/2002]
Old Jun 12, 2002 | 09:39 PM
kepani's Avatar
isn't this setup what itrsport.com runs? http://24.161.125.125/parchive_wallpaper1.html
Old Jun 12, 2002 | 09:40 PM
B2FiNiTY's Avatar
Yes...Exactly what he has.
