frame problem dc5
Old Aug 8, 2007 | 03:10 PM
david11's Avatar
Default frame problem dc5
so the other day i noticed a squeeking noise coming from the front of the car, thinking it might be the suspension or the rubber bushings...well after driving around i realized it might be something else...then i thought maybe the bumper was loose..so i get home pop the hood and some way in hell....i see that the hoodlatch at one bolt had pulled out of the frame with part of the frame still on the bolt...meaning i now i have a nickel size hole in the frame...than i look on the other side an see that the other top bolt has 2 rust cracks on each side..also i notice that the vertical bar that attaches in the middle is slight ly bent and one of the tack welds has come loose....any clue as how much it will cost in replacing or fixing all this stuff??? rest of car seems fine...can i do it myself except fixing that tack weld? or is that middle piece of the frame welded an screwed in place?
Old Aug 9, 2007 | 02:11 PM
david11's Avatar
some one please help. anywhere i can get the replacement part???
Old Aug 10, 2007 | 09:57 PM
Goy091's Avatar
Default Re: frame problem dc5 (david11)
did you buy your car used? looks like it slipped of he jack point in the front and the jack messed up the rad support and pused that top part out with it.
no sure how much it costs to fix but there is welding involved if you want a new one. the top part i think is obly $200 or so. not sure. maybe get some bigger pics to see what else is messed up
Old Aug 11, 2007 | 06:59 AM
WhiteOnRice's Avatar
Buy it from your dealer.
Old Aug 11, 2007 | 08:35 AM
david11's Avatar
im trying to save as much money as possible. im rather broke since i bought this car....im gona bring it to a body shop this week...but yea i did buy it used but i carfaxed the vin an it showed no accidents at all
Old Aug 11, 2007 | 08:46 AM
jdmdc5integra's Avatar
Default Re: (david11)
Just because no accidents showed on the carfax doesn't mean it didn't get into an accident. It just means that none were reported to the police....
Bizarre
Suspension & Brakes
Jul 19, 2008 08:08 PM
drtysohc
Mar 11, 2008 07:47 PM
HomeDepotMade
Jan 21, 2006 12:39 PM
jagged4698
Mar 8, 2004 07:26 AM
delgado200376
Sep 28, 2003 11:42 AM
