93 lude wont start
Old Aug 8, 2007 | 02:54 PM
churchman's Avatar
New User
Default 93 lude wont start
ok alil help here ppl i need it....i have a 93 prelude 2.3...it was running fine then it started be dumb would go past 3000 rpms...so i changed the distributer.it stayed the same then it just stoped running then i changed the coil plugs wires cap rotor ecu cut the cat tryed starting fluid nothing any help someone
Old Aug 8, 2007 | 02:58 PM
saikou's Avatar
Default Re: 93 lude wont start (churchman)
Does it even attempt to turn over at all? If it does, you probably have the firing order incorrect. Especially since you've changed out the distributor cap & rotor and plug wires.
Old Aug 8, 2007 | 08:25 PM
churchman's Avatar
New User
Default Re: 93 lude wont start (saikou)
i have the fireing oreder correct the car was running fine then after like an hour of driven it started to not rev past 3000 rpms i changed everything like i said the fireing order is correct has gas spark ecu is good even tryed to change that out still no diffrence
Old Aug 9, 2007 | 08:36 AM
CrxRex's Avatar
bump
Old Aug 9, 2007 | 09:02 AM
sean1121's Avatar
Do you have a CEL? If so pull the codes.
Old Aug 9, 2007 | 09:08 AM
kacivic's Avatar
engine getting spark? fuel? air?
Old Aug 9, 2007 | 03:03 PM
churchman's Avatar
New User
Default Re: (kacivic)
its getting spark fuel i dont know how ud check to see if its getting air but id say yes its getting air
joyrider58
Jan 1, 2009 10:23 PM
jdmstylez16
Oct 28, 2007 02:39 PM
John.
May 25, 2006 06:10 AM
nigel
21
Feb 2, 2004 01:56 AM
mattimo
Jan 8, 2004 01:53 PM
