welding Cast Iron.
Old Aug 8, 2007 | 02:12 PM
Soon_2b_evil's Avatar
Default welding Cast Iron.
so im about to weld a on a cast iron manifold. i know i should be using its rod for welding on it but what if i just used Carbon Steel wire instead?
Old Aug 8, 2007 | 02:23 PM
ladyfriend's Avatar
Default Re: welding Cast Iron. (Soon_2b_evil)
cast iron requires a nickel rod SMAW process or a fusion weld where a oxy/acetalene flame is used to meld the new cast filler in and fuse the two parts together.
other then that its not recomended
Old Aug 8, 2007 | 02:36 PM
all_motor_mike's Avatar
the one time that i have welded on cast iron i preheated the area being welding and used mild steel rod, using a tig welder of course.
Old Aug 8, 2007 | 02:39 PM
.RTErnie's Avatar
Default Re: welding Cast Iron. (all_motor_mike)
nickel.
Old Aug 8, 2007 | 02:41 PM
Default Re: welding Cast Iron. (ladyfriend)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladyfriend &raquo;</TD></TR><TR><TD CLASS="quote">cast iron requires a nickel rod SMAW process or a fusion weld where a oxy/acetalene flame is used to meld the new cast filler in and fuse the two parts together.
other then that its not recomended</TD></TR></TABLE>
ohok. well then looks like i might have to wait to take it to work and have it done there.
Old Aug 9, 2007 | 02:14 PM
ManBearPig4silly's Avatar
you can get nickel rod for gtaw as well. **** I think I've even seen mig wire. If might have been for copper though.
Old Aug 9, 2007 | 04:50 PM
dave@passenger's Avatar
Default Re: (ManBearPig4silly)
Use hastelloy if you can, if not 309l works in a pinch just do a really long post heat.
Old Aug 9, 2007 | 06:41 PM
Jared's Avatar
I will only weld to cast if need be for mounting a bracket or something not terribly load bearing. regardless, i get best results heating it almost glowing red, then throwing a lot of heat at it while welding. thats mig btw.
Old Aug 10, 2007 | 11:14 AM
scrubnick's Avatar
I have welded some cast iron before. I used an old AC/DC stick machine with some high nickel rod. There's a few types of cast iron rod out there. Only the high nickel rod is machinable. It, however, is rather expensive, usually 20 bucks a pound or so. I also preheated with a rose bud tipped oxy-acetylene torch.
all_motor_mike
Welding / Fabrication
Jan 26, 2008 02:08 PM
55superbeetle
Oct 2, 2007 10:14 PM
dfoxengr
24
May 15, 2006 09:12 AM
boostedcivicsir
Jan 29, 2006 11:46 AM
ComputerJLT
10
Mar 30, 2005 10:11 PM
