FS OVER 500WHP 95 Integra Fully Built By King Motorsports
Old Aug 8, 2007 | 01:41 PM
501hpintegra's Avatar
Default NO LONGER SELLING
<U>NO LONGER SELLING</U>
This is a 95 GSR that motor, tuning and trans was done by king.
This includes full motor build, trans build, brand new turbo, piping, and so on. Have a dyno sheet .Body and paint is in great condition. and everything works. Any questions IM me. Asking $17,500. obo
Here is a list
®Balanced and Blue Printed B18C by King MotorSports
®ITR Cams
®J E 84mm Pistons eagle godzilla sleeved block
®Eagle Rods
®New Main Bearings
®ITR Balanced Crank
®New oil pump
®New Mugen low temp thermostat
®Samco red coolant hoses
®J G Intake Manifold
®King Big bore throttle body
®LoveFab Ram Head exhaust manifold (2800° Ceramic Coated)
®Moroso 5 Qt oil pan
®Precisions version of the Garrett gt35r turbo– Polished housing (2800° Ceramic Coated Turbo Housing)
®40mm Tial Wastegate
®HKS sequential blow off valve
®Integra type R cylinder head Port matched, 3-angle competition valve job
®Type R Cams
®Supertech valve train
®ARC intercooler
®Mugen Hard Motor Mounts
®Fluidyne 40mm radiator
®Precision 1000cc injectors
®3-inch stainless steel exhaust
®3-inch stainless steel down pipe (2800° Ceramic Jet Coated)
®Walbro fuel pump 225 LPH
®AEM fuel filter, fuel rail, cam gears
®KMS oil catch can
®Magnacore 8.5 plug wires
®MSD full sport compact ignition
®Custom upper & lower intercooler pipes
®ACT stage 3 six puck racing clutch
®Act 8LB Flywheel
®Quaife Limited slip
®Built Trans (hardened and carbon coated components)
®Enkei J10 17x7 rims w/Falken Azenis rt615 205 40 17
®Front Brembro cross-drilled and slotted rotors
®Rear Brembro cross-drilled rotors
®Brembro front & rear brake pads
®Tokico Illumines coil-overs
®DC sports front & rear strut tower braces
®Hondata P72 ECU
®Hondata S300 computer system
®Hondata Independent gear boost controller
®Sparco Flash 5 steering wheel
®Sparco Pedal Set
®Full chrome moly roll cage
®Sparco racing seats
®Sparco 4 point Harnesses
®Jdm Air bag Eliminator Plate
®JDM Center counsel Eliminator
®JDM double Din Stereo Eliminator Plate
®Mugen Sweat Socks
® 01 ITR Stock Front Bumper cover
® 98 Stock Head lights
® 98 Stock Rear Bumper
®Gauges auto meter phantom series (fuel pressure, oil pressure, volts, boost, nitrous,
Air/fuel) 5.5” auto meter tachometer with shift light
®Was dyno tuned by King Motorsports New Berlin, WI
Modified by 501hpintegra at 6:27 PM 8/8/2007
Modified by 501hpintegra at 9:33 AM 8/9/2007
Modified by 501hpintegra at 1:15 PM 8/9/2007
Modified by 501hpintegra at 1:17 PM 8/9/2007
Modified by 501hpintegra at 2:30 PM 8/9/2007
Modified by 501hpintegra at 11:03 PM 8/12/2007
Old Aug 8, 2007 | 01:42 PM
Default Re: FS OVER 500WHP 95 Integra Fully Built By King Motorsports (501hpintegra)
Taking Offers
Old Aug 8, 2007 | 02:04 PM
LUXXXX's Avatar
pictures of the car would help.. not just motor shots
Old Aug 8, 2007 | 02:42 PM
Default Re: FS OVER 500WHP 95 Integra Fully Built By King Motorsports (LUXXXX)
trying to upload having trouble i will upload full car shots asap
Old Aug 8, 2007 | 05:27 PM
have new pics up
Old Aug 8, 2007 | 11:33 PM
idea_jdm's Avatar
yeah....i don't know if it's just my computer, but your pictures don't work.
Old Aug 9, 2007 | 04:34 AM
56g's Avatar
56g
pix dont work.
Old Aug 9, 2007 | 08:34 AM
Default Re: (56g)
tried new pics
Old Aug 9, 2007 | 12:15 PM
Default Re: (501hpintegra)
ttt
Old Aug 10, 2007 | 08:54 AM
ttt
least make offers
low ballers keep to yourself thanks
Old Aug 10, 2007 | 07:58 PM
Ohgodzirra's Avatar
bump for a nice car, this is tri's old car isn't it?
Old Aug 12, 2007 | 10:01 PM
Default Re: (Ohgodzirra)
used to be has been fully gone thru from motor to trans, turbo, injectors, body, interior, suspension, ecu, and proper TUNING and alot of little things that go along way, ect
Old Aug 13, 2007 | 11:00 AM
Ohgodzirra's Avatar
Bump again! I noticed all the changes, a few things looked familiar so I thought I'd ask, nice to see the car really cleaned up!
Old Aug 13, 2007 | 12:38 PM
Thanks for all the complements it feels really good to know hard work pays off
501hpintegra
Jul 30, 2008 06:08 PM
501hpintegra
Jun 21, 2008 06:20 AM
501hpintegra
Nov 15, 2007 12:48 PM
501hpintegra
Oct 24, 2007 08:20 AM
501hpintegra
Aug 10, 2007 08:52 AM
