Fabrication This Week @ SLS
Cool now build it so it doesnt crack under the stress and weight of the turbo like the lovefab one does, then I will ditch my full race manifold and get that one and put my oil filter back.
Because honestly sometimes this scares me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PSI2HI »</TD></TR><TR><TD CLASS="quote">Kinda hard to put AN fittings on the stock oil cooler.</TD></TR></TABLE>
Right, it setup better than stock as far as the hose clamps go, I would just rather keep them in the stock location
Looks nice, curious to see how it holds up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidwestAutoWorks »</TD></TR><TR><TD CLASS="quote">Lets not turn this into a debate about hose clamps, Im using the stock oil cooler which uses hose clamps to begin with
The stock oil cooler uses hose clamps on stainless braid? It might work but you won't see it on any of my projects.
if you want to use hose clamps then use rubber hose instead of steel braid
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .john. »</TD></TR><TR><TD CLASS="quote">
Correct. Braided line with hose clamps is just asking for trouble. Take a rubber hose in one hand and a steel braided hose in the other. Try to squeeze them both with your hands. Bet you don't have much luck squeezing the braided line, and neither does the hose clamp...
</TD></TR></TABLE>Correct. Braided line with hose clamps is just asking for trouble. Take a rubber hose in one hand and a steel braided hose in the other. Try to squeeze them both with your hands. Bet you don't have much luck squeezing the braided line, and neither does the hose clamp...
