I need to replace my motor
Old Aug 8, 2007 | 11:09 AM
oneamongthefence's Avatar
Default I need to replace my motor
I have a D16A6 (89 crx) and my timing belt broke. I pulled the head and found a big hole in piston 3 and valves gone. So I found another D16A6 motor w/out tranny and I want to install it. My question is can I just unbolt the tranny from the blown motor and swap blocks? Or do I have pull out the tranny too? It would seem to be easier if I don't have to mess with pulling axles/shift linkage and stuff like that.
thanks in advance.
Old Aug 8, 2007 | 12:44 PM
mahatma's Avatar
Default Re: I need to replace my motor (oneamongthefence)
WAY easier to pull the engine/trans as 1 piece. especially when it comes time to mate your trans to the new block. then reinstall as 1 piece.
most guys recommend doing it from under the car as well. i've only done it from the top because i never knew any better.
Old Aug 8, 2007 | 12:49 PM
garageEF's Avatar
Default Re: I need to replace my motor (mahatma)
^^ X2...trying to put the motor and tranny together while juggling them in your bay is difficult...linkage and axles arent too bad....
racebum
Aug 18, 2008 10:11 AM
93baggedcivic
May 6, 2007 11:41 AM
7808
Mar 30, 2006 06:21 AM
ComputerJLT
Oct 4, 2004 02:26 AM
Shaun
Apr 8, 2003 07:49 PM
