Alternator for B20 in Civic???
Old Jun 11, 2002 | 09:27 PM
magicwand's Avatar
Default Alternator for B20 in Civic???
Which alternator and bracket do I use when swapping a B20 into a 94 Civic?Thanks
Old Jun 12, 2002 | 03:48 PM
Newman's Avatar
New User
Default Re: Alternator for B20 in Civic??? (magicwand)
Any B-series from a 92-95 motor (has to have an OBD-1 plug on it). They're all the same.
Old Jun 18, 2002 | 03:24 PM
Charlie Moua's Avatar
Default Re: Alternator for B20 in Civic??? (Newman)
what if its' a b20 into a 90 civic ? should i then get a OBD-0 B-series altenator?
Old Jun 18, 2002 | 06:27 PM
b18cef's Avatar
Default Re: Alternator for B20 in Civic??? (Charlie)
If it is in a EG, i would use an OBD-1....just get a 94 Integra LS altenator...
Old Jun 18, 2002 | 08:13 PM
Newman's Avatar
New User
Then get a 90-91 LS or 88-91 SiR alternator... same plug. Basically, get what ever year B-series alternator to the wiring harness that you're using in your car (ex: if you have a 97 civic, and using a 97 civic harness, use a 96+ B-series alternator)
Old Jun 19, 2002 | 10:15 AM
KRiS1's Avatar
Ive heard something about this; lets say you use a 95 ls alternator distributor etc with a your b20, the bigger crank pulley of the b20 will eventually cause the LS alternator to burn out. Anyone else heard this?
Old Jun 19, 2002 | 02:34 PM
court's Avatar
25 Year Member
Default Re: Alternator for B20 in Civic??? (POS Hatchback)
dont the 89-96 b series alt have the same plug( circle) and the 97? up have the box plug
Old Jun 20, 2002 | 11:11 AM
92HB_HB's Avatar
sounds like urban legend.. how can an alternator burn out?? unless u put a great amount of electral load on it i guess.. correct me if i'm wrong..
guy_from_nerk
Mar 25, 2009 08:11 PM
irideslammed5021
Aug 5, 2007 08:55 AM
B20VTEG
Mar 20, 2005 07:33 AM
b20mike
Jul 22, 2003 06:16 PM
