What Oil?
Hey guys i was searching for what type of oil i should use on my D16Y8 but all i found was the synthetic kind.
I have 165,xxx miles on it and was thinking what type of oil i need, i was currently using 10w40 but not sure if its the correct one??
so any help is appreciated!
TIA
TIA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MDM »</TD></TR><TR><TD CLASS="quote">yea.. 116 aint nice around here, specially with no A/C
so should i stick to 10w40 or should i go to the 20's??</TD></TR></TABLE>
I would say stick with the 10. I think the 20's will be too thick for you car. On my civic Honda recommends 5w30 I believe and it works great for me even in the 90-100 degree days. I've used the 10w before and it worked fine, but I would stop there IMO.
And is it 10w30 or 10w40. I thought you would go up in weight but not the second number, but I may be wrong there.
I would run a quality 5W-30, which is the weight recommended by Honda. Also, understand that the first number in the viscosity rating is the low-temperature number, followed by the high temperature number.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MDM »</TD></TR><TR><TD CLASS="quote">Thanks all.. so 5w30 may be a good choice eh??</TD></TR></TABLE>
Yes, though 10W-30 would also be decent, and has the advantage of a narrower spread in viscosity. Since you won't be operating in very cold temperatures, the greater low-temp viscosity should not present a problem.
GetawayInMoscow
Mar 14, 2006 12:47 PM
jbsmith
Jul 6, 2004 04:44 PM
