Location of factory engine grounds?
Old Aug 8, 2007 | 04:11 AM
xrccrx's Avatar
Default Location of factory engine grounds?
Hi, I was hoping someone knows where all the engine should be grounded. I finally found that my charging problem is due to lack of/bad grounds. At some point before I bought the car a new motor was put in, seems the only ground they hooked up was the obvious one on top the vavlve cover, and they did a bad job on it at that. If I remember right there is also one over by the transmission/starter area. Anywhere else I should have grounded? Also, where is the factory ground location for the battery supposed to be, I think they moved that too.
Thanks Alot
Chad
91 CRX
89 CRX,
both red
Old Aug 8, 2007 | 05:52 AM
mahatma's Avatar
Default Re: Location of factory engine grounds? (xrccrx)
negative battery terminal to frame rail
transmission to frame rail
valve cover to (core support? i dunno wtf you call it )
actually this one goes from one of the valve cover nuts, to a nearby dedicated grounding spot in the valve cover, then to the core support.
and then there's the wire from your engine's harness that grounds to the thermostat housing.
Razr2
Oct 15, 2008 06:31 AM
Racermech
Apr 2, 2005 12:31 PM
H22CL
Jan 15, 2004 04:06 PM
hybrider
Mar 24, 2002 01:06 PM
