bad clutch master cyclinder??
Old Aug 8, 2007 | 01:06 AM
BlackCRX's Avatar
Default bad clutch master cyclinder??
Friend of mine has a 92 accord, the clutch grabs super low to the ground.
on occasion he wouldnt be able to get the car in gear, he would litterally have to lift the pedal up with his feet then press on it agian to get it in gear
the pushrod is maxed out, there are no visable leaks anywhere
is it time to replace the master cyclinder??
Old Aug 8, 2007 | 04:53 AM
JimBlake's Avatar
Default Re: bad clutch master cyclinder?? (BlackCRX)
It's possible that he only needs to bleed fresh fluid thru it. Is the reservoir empty?
Old Aug 8, 2007 | 05:34 AM
dwayne1413's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackCRX &raquo;</TD></TR><TR><TD CLASS="quote">Friend of mine has a 92 accord, the clutch grabs super low to the ground.
is it time to replace the master cyclinder??</TD></TR></TABLE>
Those were my exact symtoms when my clutch mastery cylinder went out. you can adjust where it grabs but if you cant get it in gear its getting ready to go. One thing you can do to pop it in gear is to pump the clutch a few times and then put it in gear. Thats what i had to do to get it to a mechanic.
replace it and i think you solve the problem
Old Aug 8, 2007 | 03:31 PM
BlackCRX's Avatar
thanx guys
bump for more confirmations??
Old Aug 8, 2007 | 03:41 PM
phootbag's Avatar
Default Re: (BlackCRX)
Is it leaking into the vehicle by the pushrod?
Old Aug 8, 2007 | 03:43 PM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
try replacing the slave first...the exact same thing happened to my car and it turned out to be the slave good luck
Sportsmom1456
Jul 24, 2016 01:23 PM
mrcoolhead
Jan 30, 2013 06:12 PM
dsturch1
Mar 26, 2011 07:15 PM
jaysome01
Sep 5, 2008 01:34 PM
