1 inch drop
You may have this up somewhere, but toyomatt84 how much did you drop yours? I was looking through another post and saw the thread with the pictures of your car and the drop looks perfect... very very nice btw.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thinknology »</TD></TR><TR><TD CLASS="quote">You may have this up somewhere, but toyomatt84 how much did you drop yours? </TD></TR></TABLE>
i think he's down 2"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thinknology »</TD></TR><TR><TD CLASS="quote">You may have this up somewhere, but toyomatt84 how much did you drop yours? I was looking through another post and saw the thread with the pictures of your car and the drop looks perfect... very very nice btw.</TD></TR></TABLE>
It's about 3" - 3.75" lower than stock. I didn't measure it all that much with the stock suspension on, to be honest, and I run coilovers.
howd you get it down so low? my back tires would definitely rub. as it is if ppl sit in my back seat and i hit a bump they rub!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03turboem2 »</TD></TR><TR><TD CLASS="quote">howd you get it down so low? my back tires would definitely rub. as it is if ppl sit in my back seat and i hit a bump they rub!</TD></TR></TABLE>
Where do you rub? The quarter panel or inner fender?
PS. Just to let you know, I run tall tires (same overall height as stock), so the ground clearance is more than those with shorter sidewalls. fventura03 had a dumped stance at Import Alliance, and the tires emphasized that fact even more. I think he was close to 4" from stock.
inner fender. not the top but the inside. maybe if my wheels pushed my tires out more they wouldnt. im on stock ex wheels still.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03turboem2 »</TD></TR><TR><TD CLASS="quote">inner fender. not the top but the inside. maybe if my wheels pushed my tires out more they wouldnt. im on stock ex wheels still.</TD></TR></TABLE>
Do you have a camber kit?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 »</TD></TR><TR><TD CLASS="quote">
Do you have a camber kit?</TD></TR></TABLE> only in the front
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Curiouz_G »</TD></TR><TR><TD CLASS="quote">im about 2 inches from the ground right now and i have no idea how you guys do it and not get frustrated. i cant imagine attempting it in winter time. </TD></TR></TABLE>
if i were lower i couldnt get into my driveway cuz it has one of those steep curbs lol
It's fun.
Actually, I'm a rather patient driver as it is, so slowing down a little bit more on entry/departure doesn't phase me. Snow's fun, I usually have taller than OEM tires for winter, though. It helps compensate for the lower stance.
My biggest pet peeve, is inner fender rub with wider tires. I can't seem to avoid it.
I guess that's what I get for wanting wider than OEM-spec tires.
To be honest, if I can make a new header/cat/mid-pipe section, or somehow modify the existing setup, I'd like to go a little lower next summer (1/2" or so). Right now, the cat/mid-pipe cause issues on decent bumps/pivot points. It is 2.5", and not originally from the car, so I guess that's expected.
It's fun.
Actually, I'm a rather patient driver as it is, so slowing down a little bit more on entry/departure doesn't phase me. Snow's fun, I usually have taller than OEM tires for winter, though. It helps compensate for the lower stance.My biggest pet peeve, is inner fender rub with wider tires. I can't seem to avoid it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03turboem2 »</TD></TR><TR><TD CLASS="quote"> only in the front</TD></TR></TABLE>
That would be your problem.
well i'll have to get one for the back then
</TD></TR></TABLE>well i'll have to get one for the back then
Wow... How do you get it that low? I'm assuming the coil-overs is what allows such a drop (I've never had experience with coi-overs)? I'm thinking about dropping mine but It won't be that much... as for now I have to run it in the winter
and I get alot of snow in 'ol Ohio.
You'll be surprised how low you can go with a camber kit. Before I change these out in a couple weeks, I'll show you just how low I can go with the rear of the car. The fronts are completely dumped as is. You want to talk about tire tucking?
</TD></TR></TABLE>You'll be surprised how low you can go with a camber kit. Before I change these out in a couple weeks, I'll show you just how low I can go with the rear of the car. The fronts are completely dumped as is. You want to talk about tire tucking?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thinknology »</TD></TR><TR><TD CLASS="quote">Wow... How do you get it that low? I'm assuming the coil-overs is what allows such a drop (I've never had experience with coi-overs)? I'm thinking about dropping mine but It will be that much... as for now I have to run it in the winter
and I get alot of snow in 'ol Ohio.</TD></TR></TABLE>
just put a snow plow on the front!
and I get alot of snow in 'ol Ohio.</TD></TR></TABLE>just put a snow plow on the front!
I'm in Wisconsin. Care to compare snow fall?
and I get alot of snow in 'ol Ohio.</TD></TR></TABLE>I'm in Wisconsin. Care to compare snow fall?
id go lower if it wasnt for my driveway. the front definitely has plenty more room to tuck. right now my back tires just barely tuck into teh fenders
I'm in Wisconsin. Care to compare snow fall? </TD></TR></TABLE>
im in colorado. still wanna compare?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03turboem2 »</TD></TR><TR><TD CLASS="quote">id go lower if it wasnt for my driveway. the front definitely has plenty more room to tuck. right now my back tires just barely tuck into teh fenders</TD></TR></TABLE>
I prefer the look of "level". I measure clearance from ground to the side (where the side skirts would mount). I measure (on both sides) behind the front wheel, and in front of the rear wheel. I match the numbers as best as possible, before taking it to the alignment rack.
