do i need a resistor box * i did search*
Old Aug 7, 2007 | 10:05 PM
xXSilentScreamXx's Avatar
Default do i need a resistor box * i did search*
ok i have an obd1 h22a if i use obd1 h22a injectors do i need a resistor box?
the post below says otherwise and numerous others conflict with the post below
is there a way to check if i need one ? ie* ohm load?
https://honda-tech.com/zerothread?id=2024258
Old Aug 7, 2007 | 11:16 PM
Default Re: do i need a resistor box * i did search* (xXSilentScreamXx)
bump
Old Aug 7, 2007 | 11:25 PM
1995Civic's Avatar
Whats the size of the injectors?
Search: H22 Injectors
Results: 221
You didnt search hard enough...ill allow you to do the rest of the work, im too tired for this ****
Old Aug 7, 2007 | 11:41 PM
Default Re: (1995Civic)
isnt that the size of the injector? what does that have to do with a resistor box?
Old Aug 7, 2007 | 11:43 PM
1995Civic's Avatar
Default Re: (xXSilentScreamXx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xXSilentScreamXx &raquo;</TD></TR><TR><TD CLASS="quote">isnt that the size of the injector? what does that have to do with a resistor box?
Did you run the search that i JUST gave you?
I already ran the search, and i found many threads pertaining to your question...it takes a little bit of reading bro. Not trying to be a dick, but i see this so many times on here it gets very frustrating.
Old Aug 7, 2007 | 11:52 PM
ooo i thought you said you searched for h22 injectors and they were 221cc or whatever my bad man so srry
and your not being a dick
Old Aug 7, 2007 | 11:58 PM
1995Civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xXSilentScreamXx &raquo;</TD></TR><TR><TD CLASS="quote">ooo i thought you said you searched for h22 injectors and they were 221cc or whatever my bad man so srry
and your not being a dick </TD></TR></TABLE>
No worries.
That search should be everything you need...you'll find it in there. I just dont have the time to find it or i would. Plus i dont have all the information from you that i would need. Goodluck man
Old Aug 8, 2007 | 12:01 AM
p.m'd
RicanRacer253
Oct 3, 2019 10:21 PM
raidacaipo
16
Feb 15, 2009 12:26 AM
LSEGHATCH
Oct 29, 2005 03:57 PM
huge230
24
Oct 3, 2005 11:41 AM
2000si
Mar 26, 2004 06:13 AM
