How correct are these pinouts?
Old Aug 7, 2007 | 09:46 PM
SolAssassin's Avatar
Default How correct are these pinouts?
I'm doing an OBD0 swap into a DPFI EF, and I was lucky enough to come across a JDM B16 harness. The pinouts I have go as follows:
OBD 0
Pinout '90-1 DX (Std.) '89-92 EF8/9 SiR
A1 Aux INJ w/A3 No.1 INJ
A2 GRD w/A4 to Main Relay GRD w/A4 to Main Relay
A3 Aux INJ w/A1 No.2 INJ
A4 GRD w/A2 to Main Relay GRD w/A2 to Main Relay
A5 Main INJ w/A7 No.3 INJ
A6 Purge Cut-Off Solenoid Valve Purge Cut-Off Solenoid Valve
A7 Main INJ w/A5 No.4 INJ
A8 Lock-up Control Solenoid Valve Spool (VTEC) Solenoid Valve
A9 - -
A10 EGR Valve (CA A/T Only) Pressure Regulator Cut-Off Solenoid Valve
A11 EACV w/A17 EACV
A12 Main Relay w/A14 Main Relay w/A14
A13 Main Relay w/A15 Main Relay w/A15
A14 Main Relay w/A12 Main Relay w/A12
A15 Main Relay w/A13 Main Relay w/A13
A16 GRD w/A18 GRD w/A18
A17 - -
A18 GRD w/A16 GRD w/A16
B1 Hazard Fuse w/Brake Switch Hazard Fuse w/Brake Switch
B2 Tandem Valve Control Solenoid Valve -
B3 A/C Clutch Relay A/C Clutch Relay
B4 Radiator Fan Relay -
B5 Alternator Oil Pressure Switch
B6 Check Engine Light Check Engine Light(10A)
B7 Shift Position Sensor (A/T Only) -
B8 A/C Switch A/C Switch
B9 - Brake Switch
B10 - Crank Angle Sensor
B11 Shift Position Sensor (AT Only) Rear Defogger Switch
B12 - Crank Angle Sensor
B13 No.2 Fuse (10A) No.2 Fuse (10A)
B14 Alternator Alternator
B15 Igniter Unit w/B17 Igniter Unit w/B17
B16 Speed Sensor Speed Sensor (Electrical)
B17 Igniter Unit w/B15 Igniter Unit w/B15
B18 - -
B19 ELD Knock Sensor
B20 Ign. Timing Adj. Connector Ign. Timing Adj. Connector
C1 Crank Angle Sensor Cylinder Position Sensor
C2 Crank Angle Sensor Cylinder Position Sensor
C3 TDC Sensor TDC Sensor
C4 TDC Sensor TDC Sensor
C5 TA Sensor TA Sensor
C6 TW Sensor TW Sensor
C7 Throttle Angle Sensor Throttle Angle Sensor
C8 EGR Valve Lift Sensor (CA A/T Only) O2 Sensor B
C9 PA Sensor P/S oil switch
C10 Brake Switch Brake Switch
C11 MAP Sensor MAP Sensor
C12 PA Sensor Throttle Angle Sensor
C13 PA Sensor Throttle Angle Sensor
C14 MAP Sensor MAP Sensor
C15 MAP Sensor MAP Sensor
C16 O2 Sensor A O2 Sensor A
It's easier to read by going to http://hondaswap.com/reference...8667/
Can anyone verify these as correct? I have also noticed that it's possible that some things may have a different name for the same thing. Anyone have experience with this wiring combo?
boost99
May 9, 2011 12:45 PM
dalek
Dec 26, 2007 12:21 PM
90civicturboed
Jul 29, 2005 08:47 PM
