FUEL FILTER QUESTION ON EM2s
HAVE ANY OF YOU GUYS WITH EM2s HAD PROBLEMS WITH CLOGGED FUEL FILTERS?
MY PROBLEM IS THAT MY CAR IS RUNNING SLUGGISH AND NOT RESPONDING WHEN I PRESS DOWN HARD ON THE GAS PEDAL. IN OTHER WORDS IT STUMBLES.
This has been covered many times. You may want to try searching first.
The fuel filter is in the fuel tank, along with the fuel pump, so replacing it will be a pain. Not to mention it is not a common item to go bad. Try using some fuel injector cleaner.
PS. Turn off your Caps. Lock.
crnimacak
Apr 21, 2006 10:11 PM
