is the VSS in a d-series trans removeable?
Old Aug 7, 2007 | 07:42 PM
dragonfly2k3's Avatar
Default is the VSS in a d-series trans removeable?
This is the question, and i have no idea.
Old Aug 7, 2007 | 07:46 PM
lluks_844's Avatar
Default Re: is the VSS in a d-series trans removeable? (dragonfly2k3)
yes you can remove it, but i dont see y other than filling with tranny fluid or raplacing it.
Old Aug 7, 2007 | 07:53 PM
1995Civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragonfly2k3 &raquo;</TD></TR><TR><TD CLASS="quote">This is the question, and i have no idea. </TD></TR></TABLE>
Yes it is removable....but why?
Old Aug 7, 2007 | 08:01 PM
Default Re: is the VSS in a d-series trans removeable? (1995Civic)
My car throws a cel for a VSS and is making tons of gear noise. Im thinking that possibly it siezed up. Which bolt is it? just teh long one ontop? i know there are 2 for the electrical sensor than then one more, all 3 are out but it seems pretty stuck. Any tricks?
Old Aug 7, 2007 | 09:05 PM
Everyones Hero's Avatar
Push it to the side to break the seal. It probably hasn't been pulled in a long *** time. Corrosion builds up & makes it difficult to pull out. (Personal experience. )
Old Aug 7, 2007 | 09:07 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragonfly2k3 &raquo;</TD></TR><TR><TD CLASS="quote">My car throws a cel for a VSS and is making tons of gear noise. Im thinking that possibly it siezed up. Which bolt is it? just teh long one ontop? i know there are 2 for the electrical sensor than then one more, all 3 are out but it seems pretty stuck. Any tricks? </TD></TR></TABLE>
It's the sensor towards the rear of the trans on top with the 10mm bolt connected to it. Unbolt the bolt, push it to the side a bit, and pull it out. You'll probably have to wiggle it a bit.
Old Aug 7, 2007 | 09:12 PM
gtlaw1's Avatar
try shifting once you removed the bolt and have it spinning also try neutral
Old Aug 8, 2007 | 12:31 AM
Mista Bone's Avatar
D Tranny Guru
ISB + VSS issue.........or a drivers side diff bearing going out.
Old Aug 8, 2007 | 10:15 AM
Default Re: (Mista Bone)
all wrong, previous owner put in too long of a bolt that hit a gear and bent, thus ruining the threads on the case when unthreaded, Im pissed.
RS2 FAB
Welding / Fabrication
Feb 10, 2008 12:28 PM
Rah Rah
Honda Motorcycles
17
Mar 15, 2007 09:22 AM
1994CivicGS-R
21
Aug 6, 2006 05:46 AM
EFstyle
13
Jun 11, 2006 12:31 PM
builthatch
Aug 17, 2005 05:37 AM
