Axle problem =/
So heres the deal i have a h22 dohc vtec motor in a 1993 civic hatchback. The other day my axle boot busted near the trany. So i went to replace it today and i cant seem to find what kind of axle it is, the closet axle that i have found to be closest was an axle from an accord 2.2 motor. But the only problem was the shaft wouldn't go threw the rotor, but it fit into the trany perfectly. Does anyone have any suggestions please let me know asap.
check the hybrid forum for info on your setup.
Did you not do this swap yourself? Call up whoever did it and figure out what they used. From what I understand there are a few different options for axle setups.
Ok i read the hybrid forum on the h22 builds...but all it really explained was that you must have a prelude or accord cv joint to go into the trany, but still leads me to wonder why the accord or prelude axle i bought wouldn't fit threw my rotor.
you probably got the civic stock rotors, which means u have to custom ur axle, not very expensive.
you just have to buy an axle for the h and for the stock civic.
pull'em apart and put them back together..
had a buddy do it on his h22 swap
make sure u find somebody that knows what their doing.
MugenAccordSedan
May 27, 2004 11:41 PM
