mWhich Transmission?
Old Jun 11, 2002 | 07:53 PM
td04civic's Avatar
Default mWhich Transmission?
If i use a sir 1 b16A motor in my 93 civic can i use a gsr hydro transmission instead of using the cable one? Thanks in advance.
Troy
Old Jun 11, 2002 | 08:55 PM
Kamin's Avatar
Default Re: mWhich Transmission? (td04civic)
yea but your gonna need more than just the tranny
i hope you didnt spend money on the first gen motor.
youll regret it.
Old Jun 12, 2002 | 05:38 AM
Ceeveek's Avatar
New User
Default Re: mWhich Transmission? (KAMiN)
hey KAMin, you have a coupe? What kind of times are you running with your set up?
Old Jun 12, 2002 | 10:46 AM
Jackson's Avatar
You can run the gsr hydro tranny, but I would suggest using the hyrdo b16a tranny.
Old Jun 12, 2002 | 10:49 AM
td04civic's Avatar
Default Re: mWhich Transmission? (Jedi Master)
so a 94-95 delsol vtec or a 99/00 si transmission will bolt right up to a first generation B16? I wanted to know because i can get the b16 for pretty cheap and then just buy the hydro transmission.
Old Jun 12, 2002 | 10:52 AM
Jackson's Avatar
Yes, it bolts up perfectly.
Old Jun 12, 2002 | 01:09 PM
Kamin's Avatar
it runs ***, high 15's i have a broken clutch and stock exhaust, its easialy capable of mid-low 15's.
anyway, DONT buy the first gen b16!
you need more than just the transmission to get it to work in your car!
VTEC2841
May 9, 2007 04:12 PM
sweetbai00000
Mar 27, 2007 09:23 PM
Agent Zero
Sep 17, 2005 06:22 AM
Gr8Wyt3
10
Sep 3, 2002 09:47 AM
allmtr
Jul 9, 2002 11:38 PM
