Replacing Inner & Outer Tie Rods - what should be replaced on steering gearbox
Old Aug 7, 2007 | 05:28 PM
6SPD_EK's Avatar
Default Replacing Inner & Outer Tie Rods - what should be replaced on steering gearbox
This is on a 1994 DX Hatch - non power-steering
I will be replacing inner & outer tie rods... boots & ball joints will also be replaced. what other parts (tie rod or steering gear box related) should be replaced for preventative maintenance? please post #'s from diagram
http://www.slhondaparts.com/br...=true
these guys are reputable BTW with good prices & their parts really are oem quality
-tie rod set http://cgi.ebay.com/ebaymotors...wItem
Old Aug 7, 2007 | 05:34 PM
vrrodri's Avatar
you have to inspect under the car and determine if something is bad...I replaced the whole raqck and pinion since the outer tie rods were fused to the box and could not be removed without cutting them off
Old Aug 7, 2007 | 05:38 PM
6SPD_EK's Avatar
Default Re: (vrrodri)
i thought there was some bushing on rack that people suggested replacing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vrrodri &raquo;</TD></TR><TR><TD CLASS="quote">you have to inspect under the car and determine if something is bad...I replaced the whole raqck and pinion since the outer tie rods were fused to the box and could not be removed without cutting them off</TD></TR></TABLE>
did you have the special tool for removing inner tie rod ends?
Old Aug 7, 2007 | 06:15 PM
6SPD_EK's Avatar
Default Re: Replacing Inner & Outer Tie Rods - what should be replaced on steering gearbox (6SPD_EK)
replace 8, 10 (suggested by members here) 13, 14, 20 (x2)
inspect rack #9 & pinion #7
Modified by 6SPD_EK at 1:57 AM 8/8/2007
FrontwheelENT
Aug 31, 2014 07:49 AM
bboixtc
Mar 25, 2008 09:56 PM
msinsky14
15
May 3, 2007 11:21 AM
92integra-R
Jul 20, 2006 03:53 PM
