project 2000 dc2, fresh paint, jdm front, and shaven inside!
Old Aug 7, 2007 | 05:21 PM
EARLdaSQUIRREL's Avatar
official honda whore
Default project 2000 dc2, fresh paint, jdm front, and shaven inside!
well i just got done repainting my friends 95 civic coupe and decided i wanted to finally get to work on my car
picked up a jdm front for it and did a rough install before paint:
got my friends car done, sneak peak, should have it running within a couple of weeks, i basically redid this whole car, new quarters, fixing the wing and full paint (all jams)
and the other day i decided to tear into my car and get started, should have the front jams done within the next day or 2 and have the whole car done this weekend
and in my opinion the worst part of all the work i hate sanding the frames of hoods especially when they are covered in black soot
updates: aug 13
update: aug 14th
aug 17: its all done, just need a cut and buff and i will post up final pics
updated pic still needs wetsand and buff
while im doing this i also polished all my rims
hoping to keep updating and sorry for the shitty quality pics
Modified by coptzer at 1:08 AM 8/15/2007
Modified by coptzer at 2:29 AM 8/17/2007
Modified by coptzer at 6:03 PM 8/18/2007
Old Aug 7, 2007 | 07:14 PM
kiddcarbuff's Avatar
should look good! what colro u doing it? what paint u using, what guns?
Old Aug 7, 2007 | 09:43 PM
Lenthrax's Avatar
Default Re: project 2000 dc2, fresh paint, jdm front, and shaven inside! (coptzer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coptzer &raquo;</TD></TR><TR><TD CLASS="quote">
umm.. maybe you should of used a stuff like simple green or other stuff and wash it off to clean it before sanding
Old Aug 7, 2007 | 09:51 PM
Default Re: project 2000 dc2, fresh paint, jdm front, and shaven inside! (Lenthrax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lenthrax &raquo;</TD></TR><TR><TD CLASS="quote">
umm.. maybe you should of used a stuff like simple green or other stuff and wash it off to clean it before sanding</TD></TR></TABLE>
i used engine cleaner and a pressure washer along with scrubbing the **** out of it, even if it was clean i still hate sanding all those little nooks n ****
Old Aug 9, 2007 | 02:38 PM
goota's Avatar
Did you just weld the top of a JDM radiator support to the USDM one?
Old Aug 9, 2007 | 03:47 PM
Default Re: (goota)
yes i used the top of the jdm radiator support
Old Aug 9, 2007 | 07:01 PM
goota's Avatar
hmmmmmmmmm, that sounds like a good idea. :D
Old Aug 9, 2007 | 10:31 PM
EKFerioHawaii's Avatar
Default Re: (goota)
Under hood = Tide w/bleach + 3M Magenta scuff pad.
Does wonders....
Old Aug 12, 2007 | 09:01 PM
Default Re: (EKFerioHawaii)
updated with some more pics, have jams all done, just doing final coat of icing and then primer tomorrow, and paint on tuesday
Old Aug 13, 2007 | 09:17 AM
Genuine Rolla's Avatar
not bad at all. I'll keep an eye on this thread.
Old Aug 14, 2007 | 09:09 PM
new pics bump
i just wetsanded the primer with 600, going to shoot tomorrow while the temps should be around 75 and humidity below 50%
Old Aug 14, 2007 | 10:41 PM
Civic-Kids's Avatar
tight ****... keep on updating...
Old Aug 16, 2007 | 12:31 PM
can't wait to see how it comes out.
Old Aug 16, 2007 | 10:29 PM
its all done, one pic i took today was posted...
Old Aug 18, 2007 | 02:03 PM
new pic bump
Old Aug 20, 2007 | 07:07 PM
msinsky14's Avatar
looks sexy and shiny. how hard is painting for a first timer?
Old Aug 20, 2007 | 07:15 PM
Axemurderer23's Avatar
Default Re: project 2000 dc2, fresh paint, jdm front, and shaven inside! (msinsky14)
Looks nice brian, have to check it out when i come home
Old Aug 23, 2007 | 06:40 PM
vestalfootball72
Guest
Posts: n/a
Default Re: project 2000 dc2, fresh paint, jdm front, and shaven inside! (Axemurderer23)
balllin
Old Aug 25, 2007 | 07:43 PM
nikolai.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msinsky14 &raquo;</TD></TR><TR><TD CLASS="quote">looks sexy and shiny. how hard is painting for a first timer?</TD></TR></TABLE>
quite frankly its impossible for a first timer to do a repaint and come out with an oem finish. you need to practice alot. hopefully as you progress your expectations will reduce until they meet your capability. if you have someone that knows what they are doing teach you, it helps tremendously.
Old Aug 25, 2007 | 08:10 PM
msinsky14's Avatar
Default Re: project 2000 dc2, fresh paint, jdm front, and shaven inside! (nikolai.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nikolai. &raquo;</TD></TR><TR><TD CLASS="quote">
quite frankly its impossible for a first timer to do a repaint and come out with an oem finish. you need to practice alot. hopefully as you progress your expectations will reduce until they meet your capability. if you have someone that knows what they are doing teach you, it helps tremendously.</TD></TR></TABLE>
that i do
my friends dad owns a shop, but hes drunk half the time, so i have no clue what he was saying to me aout painting my car, but he gave me list of grits and showed me how to lay clear.
Old Aug 26, 2007 | 01:18 AM
Reza^'s Avatar
what kind of primer is that used on your fenders?
the redish color...
Old Aug 27, 2007 | 08:31 PM
GSR-T-'s Avatar
looks really good but you def need some better pigs
Old Aug 28, 2007 | 04:08 PM
DAneronimo's Avatar
Default Re: project 2000 dc2, fresh paint, jdm front, and shaven inside! (Reza^)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reza^ &raquo;</TD></TR><TR><TD CLASS="quote">what kind of primer is that used on your fenders?
the redish color...</TD></TR></TABLE>
it might be sealer; i've seen sealer in red before
Old Oct 8, 2007 | 04:02 PM
new pic
Old Oct 11, 2007 | 08:55 AM
vestalfootball72
Guest
Posts: n/a
Default Re: project 2000 dc2, fresh paint, jdm front, and shaven inside! (DAneronimo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAneronimo &raquo;</TD></TR><TR><TD CLASS="quote">
it might be sealer; i've seen sealer in red before</TD></TR></TABLE>
looks like high build primer
car looks sickk-
