My thermostat gauge went past red on my way to NYC
Old Aug 7, 2007 | 04:57 PM
businessmanph's Avatar
Default My thermostat gauge went past red on my way to NYC stop and go traffic ac on
I had my air condition on setting 4 (non circulation) and I was in stop and go traffic near an ez-pass. My RPMs were dipping below 100. I noticed my thermostat gauge past red and I immediately turned off the ac and put the car in neutral. The temperature when down slowly. Lucky my car didn’t shut off, smoke, or get fucked up that I know of.
Is this normal for a car to over heat in stop and go traffic with ac on?
BTW
My coolant got flushed and thermostat change at 86k. My coolant reservoir was topped off. I use the orange Prestone coolant.
Old Aug 7, 2007 | 05:10 PM
oem_certified_accord's Avatar
Default Re: My thermostat gauge went past red on my way to NYC stop and go traffic ac on (businessmanph)
rad fans spinning?
Old Aug 7, 2007 | 05:59 PM
rival12's Avatar
this usually happens when a rad hose goes....or it happened to me anyways...check-em, replace as necessary. sometimes those hairline cracks will do it....sucks when you can't see which hose is gone...goodluck!
Old Aug 7, 2007 | 06:26 PM
redbull-1's Avatar
Check that the A/C condenser fan is working.
Old Aug 7, 2007 | 10:38 PM
mozzandherb's Avatar
Honda-Tech Titanium Member
Could be the thermostat, check the pressure in your coolant, flush the coolant if needed, check to make sure the fans are working properly
eman96
Jul 29, 2014 06:53 PM
ALDJ253
Mar 9, 2014 07:23 AM
JonBaillio
15
Aug 24, 2010 09:33 AM
TOO MUCH TORQUE
Jul 28, 2010 09:21 PM
mystikalflip
Jul 22, 2008 06:32 AM
