Why cant I use the coolant bleeder valve for turbo coolant lines.
Old Aug 7, 2007 | 04:10 PM
91crxturbo's Avatar
Default Why cant I use the coolant bleeder valve for turbo coolant lines.
I have never used the bleeder valve before and I would love to ditch the little valve and insert an -AN fitting in there to run a colant like to my oil/water cooler gt30r. Some people have said that this should not be done, and im just trying to figure out why? I was thinking of enlarging the hole slightly to allow for more coolant flow.
what do you guys think?
Old Aug 7, 2007 | 05:25 PM
Topdawgg's Avatar
Default Re: Why cant I use the coolant bleeder valve for turbo coolant lines. (91crxturbo)
you can
Old Aug 7, 2007 | 05:32 PM
a1320addict's Avatar
Default Re: Why cant I use the coolant bleeder valve for turbo coolant lines. (Topdawgg)
And if you do so, you'll need a 4' wide drain pan when you need to drain your coolant.
Get a -6 aluminum weld-on. Much cleaner, and less messy
Old Aug 7, 2007 | 11:51 PM
91crxturbo's Avatar
Default Re: Why cant I use the coolant bleeder valve for turbo coolant lines. (a1320addict)
could i use that big coolant drain bolt on the front of the head for the return coolant line?? So from the bleeder valve from the bleeder valve to the turbe, then from the turbo to the coolant drain bolt on the head??
Old Aug 8, 2007 | 05:24 AM
Use the plug on the front of the block, about 5" to the left from the dipstick.
Old Aug 8, 2007 | 08:26 AM
91crxturbo's Avatar
what size -AN lines should i run?? Does it really matter?
Old Aug 8, 2007 | 08:45 AM
-6 is more than sufficient. If you'd like, I have all the part numbers needed, PM me if you want me to foward them to you
Old Aug 8, 2007 | 10:34 AM
Running925's Avatar
I'd like to see a pic of this arrangment. I think it would look much cleaner than most installs of a water cooled turbo.
Old Aug 8, 2007 | 10:58 AM
Default Re: Why cant I use the coolant bleeder valve for turbo coolant lines. (Running925)
Here are some pictures:
For Reference
#1 is the feed off the block, #2 is the feed into the cartridge
#3 is the return off the cartridge, #4 is the return to the radiator.
Old Aug 8, 2007 | 11:05 AM
91crxturbo's Avatar
Can my return line(#4) can be plugged into my coolant bleeder valve? I would rather rather use the bleeder valve then tap into my radiator.....thanks for the delp addict.
Old Aug 8, 2007 | 11:38 AM
Default Re: (91crxturbo)
You could do it, however I really would advise you to just have a weld-on fitting added to the radiator.
Old Aug 8, 2007 | 05:02 PM
xsi-t's Avatar
that looks very clean good job
Old Aug 8, 2007 | 05:54 PM
Default Re: (xsi-t)
Thanks
If I can find some time this week, it may actually be done
Old Aug 8, 2007 | 09:22 PM
91crxturbo's Avatar
Why would a weld on fitting to the radiator be better?? would the bleeder valve not flow enough??
Old Aug 8, 2007 | 11:32 PM
V-SPEC 1's Avatar
Default Re: (a1320addict)
on that setup, is there enough pressure for the coolant to actually goes up to the turbo and comes out and into the radiator? thanks.
Old Aug 9, 2007 | 07:31 AM
agrn93ls's Avatar
Default Re: (V-SPEC 1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by V-SPEC 1 &raquo;</TD></TR><TR><TD CLASS="quote">on that setup, is there enough pressure for the coolant to actually goes up to the turbo and comes out and into the radiator? thanks.</TD></TR></TABLE>
the way 1320addict is doin it is prob the best i have seen it is goin with the water flow and doing the same as the upper radiator hose. except is getting water right after the water pump before it sees the head. great way to run it.
Old Aug 16, 2007 | 05:00 PM
xsi-t's Avatar
1320 how did you get that on the drain plug???
Old Aug 16, 2007 | 09:28 PM
Default Re: Why cant I use the coolant bleeder valve for turbo coolant lines. (xsi-t)
huh?
Old Aug 17, 2007 | 05:44 AM
White Smoke's Avatar
i my honda
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xsi-t &raquo;</TD></TR><TR><TD CLASS="quote">1320 how did you get that on the drain plug???</TD></TR></TABLE>
Take out the drin plug, tap it to 1/4npt, then install a 1/4npt to -6 or -8 an adapter.
Do NOT tap it while the plug is in the block! This was a junk block and was not re-used. (pic borrowed from abnaasefmb)
Or you can buy this fitting from honda and go the much less expencieve route and just clamp your hose on. (I believe this fits but don't quote me on that, check first)
Old Aug 17, 2007 | 03:52 PM
xsi-t's Avatar
Default Re: Why cant I use the coolant bleeder valve for turbo coolant lines. (White Smoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>Nice man thanks
Old Aug 17, 2007 | 04:38 PM
HiProfile's Avatar
Thats really the million dollar question. Do you people realize that there is very little pressure drop between the bleed plug and drain plug? If you don't have a pressure differential, then water won't move. The pressure drop from the fittings, tubes, and turbo passages has to be greater than that pressure differential between the two water taps. I've actually considered drilling a hole behind the water pump (into the block), and tapping a 1/8" or larger fitting to get coolant directly after it leaves the pump fins. Its mainly for increased flow (highest pressure at that point), not because its much cooler.
IMO the best spot besides that for the supply is the drain plug, and for the return it would be as close to the pump inlet as possible. The FITV hose would be best (bypasses t-stat for just the turbo), or any hose that goes to the t-stat inlet cover.
Old Aug 19, 2007 | 01:51 PM
xtremeness101's Avatar
Default Re: (HiProfile)
Old Aug 21, 2007 | 10:21 AM
TunerToys's Avatar
Bump for an answer to this question!
Old Aug 21, 2007 | 10:57 AM
BodyKits NW's Avatar
Default Re: (TunerToys)
I used the bleeder valve. I drilled and tapped it for a fitting I got from Stan@Fastturbo. I run a -6 line from there to the turbo. Then I have another fitting welded to the bottom of my radiator tank for the other -6 line. Seems to be working, but I did notice my temps go up about 8-10 degrees.
Old Aug 21, 2007 | 05:40 PM
TunerToys's Avatar
Default Re: (BodyKits NW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BodyKits NW &raquo;</TD></TR><TR><TD CLASS="quote">I used the bleeder valve. I drilled and tapped it for a fitting I got from Stan@Fastturbo. I run a -6 line from there to the turbo. Then I have another fitting welded to the bottom of my radiator tank for the other -6 line. Seems to be working, but I did notice my temps go up about 8-10 degrees.
I'm okay with using the bleeder valve as a return for the coolant, but am wanting to know if anyone has first hand experience with the flow results of the setup mentioned below.
BTW instead of tapping and messing with the bleeder port, you can use one of our water port adapters (for the D series only, so far.). Here is a pic...
You can use it to install a water return, and a water temp sensor, and still have the stock bleeder.
Anyone have an answer for how much flow you get with the setup mentioned earlier?
Craig
