Civic stopped running
Old Aug 7, 2007 | 03:27 PM
DaaveW's Avatar
Default Civic stopped running
Civic 91, started as normal. Vehicle left warming up, when we returned 10 minutes later it was shut down. Vehicle will not fire, everything cranks, dash lights up, everything works however no start. Fuses are all good under dash, fuse block by battery. SO ndoes anyone want to take a stab at it. Thanks for any and all input.
Old Aug 7, 2007 | 03:50 PM
rpared01's Avatar
Default Re: Civic stopped running (DaaveW)
did you check the alternator ?
Old Aug 7, 2007 | 03:55 PM
hatchling37's Avatar
Check dist. cap and rotor. Check fuel filter and plugs. These would be my first guess...
Take off your oil cap and look inside while someone cranks it over. If you don't see any of the valvetrain moving, stop immediately. Hopefully you haven't bent your valves if your timing belt went.
pisatower
Apr 15, 2009 05:22 PM
vw eater
Dec 3, 2006 12:03 PM
whitelightning
Aug 24, 2005 05:26 PM
KiNG $h!t
19
Aug 26, 2004 11:14 AM
red91g2
28
Jan 15, 2004 09:55 AM
