o you know if the d15 d15 and d16 crank pulley
Old Jun 11, 2002 | 07:28 PM
maximedx's Avatar
Default d15 and d16 crank pulley
do you know if the d15 and the d16 crank pulley is the same because the d15 is lighter than d16.do you know if the timming mark are the same on the two or affect the timming.
[Modified by maximedx, 11:29 PM 6/11/2002]
Old Jun 11, 2002 | 07:43 PM
maximedx's Avatar
Default Re: d15 and d16 crank pulley (maximedx)
nothing can i help me
Old Jun 12, 2002 | 04:19 AM
Mista Bone's Avatar
D Tranny Guru
timing marks are the same, but <U>DO NOT</U> run a 1.5L pulley on a 1.6L, bearings will die quickly.
Old Jun 13, 2002 | 07:16 PM
maximedx's Avatar
Default Re: d15 and d16 crank pulley (Mista Bone)
my motor is balanced with d15 pulley so i think that is correct so if not can i put the d16 pulley. So on the pulley what is the tdc mark i have three marks and one other is separated of the three other so what the right mark.
[Modified by maximedx, 11:19 PM 6/13/2002]
Old Jun 13, 2002 | 07:18 PM
OldSchoolCrxSiR's Avatar
use the correct one! or you will be pissed!
Old Jun 13, 2002 | 07:23 PM
maximedx's Avatar
Default Re: d15 and d16 crank pulley (HondaHb916)
yes i think is better to use the d15 pulley because it's balanced with the motor.
91zSi
Dec 26, 2005 03:31 PM
geldingmakr
Aug 3, 2004 10:51 AM
