help!! slick tire size on gsr
Old Aug 7, 2007 | 11:21 AM
BMaDOHC's Avatar
Default help!! slick tire size on gsr
whats up guys. I was wondering if a 22/8/13 hoosier slick would clear my buddies gsr brakes. its on a gsr but we are wondering if 13 inch rims will clear his factory brakes. also is this a decent size slick for a gsr running about 12 lbs of boost with built internals.what do you guys recommend. thanks for the help
Old Aug 7, 2007 | 11:30 AM
morgan@synapse motorsport's Avatar
Default Re: help!! slick tire size on gsr (BMaDOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BMaDOHC &raquo;</TD></TR><TR><TD CLASS="quote">whats up guys. I was wondering if a 22/8/13 hoosier slick would clear my buddies gsr brakes. its on a gsr but we are wondering if 13 inch rims will clear his factory brakes. also is this a decent size slick for a gsr running about 12 lbs of boost with built internals.what do you guys recommend. thanks for the help</TD></TR></TABLE>
it depends on the wheel most likely not. lenso makes a 13" wheel that clears gsr brakes.
Old Aug 7, 2007 | 11:55 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: help!! slick tire size on gsr (mike@synapse motorsport)
lots of people run 13's over gsr brakes. my bogarts clear, they need a spacer because the hub is flat, and needs a little to clear the caliper bracket. but yes 13's will fit over gsr brakes.
tire size depends on power. 22's are a good all motor height.
23's or even 24.5-25's depending on your power may suit you better.
if it is making power, you may hit the limmiter or run into 5th gear on 22's.
Old Aug 7, 2007 | 01:23 PM
BMaDOHC's Avatar
Default Re: help!! slick tire size on gsr (boostedcivicsir)
thanks guys
jdmcoop
Jul 8, 2007 05:51 PM
CRXBart
19
Nov 5, 2006 06:03 AM
GIANT
Mar 14, 2006 09:42 AM
DevineCRX
Jul 4, 2002 05:46 PM
Mr. Softee
Dec 25, 2001 04:59 PM
