Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Help w/ turn signal issue
Old Aug 7, 2007 | 07:28 AM
mikkellucci's Avatar
Default Help w/ turn signal issue
2003 Civic LX sedan, automagic:
I'm a bit embarassed to post this but cleary I'm missing something here...
My right (passenger) turn signal is flashing hyper fast. I've check (replaced) the passenger side turn signal bulb, taillight turn signal bulb, brake light bulb, high beam bulb AND headlight bulb. Also checked all fuses! All lights are working, they just blink uber fast. WTF is going on; what am I missing? Is there a relay that could need replaced, a bad ground? Any help is greatly appreciated.
Thanks.
Old Aug 7, 2007 | 07:32 AM
thinknology's Avatar
Default Re: Help w/ turn signal issue (mikkellucci)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikkellucci &raquo;</TD></TR><TR><TD CLASS="quote">2003 Civic LX sedan, automagic:
Thanks.
Thats your problem, it's no ordinary civic, maybe it's supposed to be like that... it is magic after all...
If everything is working what's the problem? That is kind of odd though, never heard of that before. All your other lights are working fine?
Old Aug 7, 2007 | 07:33 AM
^haha. Oh, its very ordinary w/ no mods. Its my new daily driver.
After an archived content search: I realized that my door chime isnt working either. What is the relation here?
Old Aug 7, 2007 | 07:35 AM
Default Re: (mikkellucci)
Maybe a possible short... I'll help ya research... I'm at work so I'm not doing anything. lol
Old Aug 7, 2007 | 07:52 AM
stinkypinky1011's Avatar
DID YOU CHANGE THE BULB TO THE SAME ONE OR SOMETHING DIFFERENT CAUSE I CHANGED MINE TO L.E.Ds AND THEY BLINK SUPER FAST.
Old Aug 7, 2007 | 07:56 AM
Thanks. Its the same wedge type # bulb every where. There are no mods to this car. I'm thinking its a short after searching more. I'll have to check a few things when I get some time. Thanks guys.
Old Aug 7, 2007 | 07:59 AM
Default Re: (stinkypinky1011)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stinkypinky1011 &raquo;</TD></TR><TR><TD CLASS="quote">DID YOU CHANGE THE BULB TO THE SAME ONE OR SOMETHING DIFFERENT CAUSE I CHANGED MINE TO L.E.Ds AND THEY BLINK SUPER FAST.</TD></TR></TABLE>
Stop yelling at us <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikkellucci &raquo;</TD></TR><TR><TD CLASS="quote">Thanks. Its the same wedge type # bulb every where. There are no mods to this car. I'm thinking its a short after searching more. I'll have to check a few things when I get some time. Thanks guys.</TD></TR></TABLE>
It sounds like a wiring problem to me as well
Old Aug 7, 2007 | 08:00 AM
^Yeah, the car was 'tapped' on the front pass side...they missed something in repair; hence why I bought it so cheap.
Old Aug 7, 2007 | 08:02 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikkellucci &raquo;</TD></TR><TR><TD CLASS="quote">^Yeah, the car was 'tapped' on the front pass side...they missed something in repair; hence why I bought it so cheap. </TD></TR></TABLE>
Lol sounds about right then...
Old Aug 7, 2007 | 08:03 AM
Default Re: (thinknology)
IM NOT YELLING IM JUST SO HAPPY. LOL sorry for the caps im at work and i use it all day.
Old Aug 7, 2007 | 08:05 AM
hahaha I know what you mean the system I use requires CAPS and keep switching on and off screwin stuff up
Old Aug 7, 2007 | 07:26 PM
toyomatt84's Avatar
Sanji
I think your turn signal module is actually broken. I've had that happen in a Chevrolet. Usually when there's a short, it also might send a shock to the module, throwing it off balance. Otherwise, it could be just an ordinary short in the wiring, which will be a pain to locate.
Old Aug 8, 2007 | 02:13 AM
Default Re: (toyomatt84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 &raquo;</TD></TR><TR><TD CLASS="quote">I think your turn signal module is actually broken. I've had that happen in a Chevrolet. Usually when there's a short, it also might send a shock to the module, throwing it off balance. Otherwise, it could be just an ordinary short in the wiring, which will be a pain to locate.</TD></TR></TABLE>
There's an idea, I forgot that I had a bike that kind of a similar situation occured... something to check out
Old Aug 8, 2007 | 03:33 PM
phootbag's Avatar
Bulbs that blink fast are usually caused by a high resistance issue rather than a short. I have encountered a bad connection that caused the turn signal to activate twice as fast just like it would if one were burned out. I suspect a voltage drop somewhere, assuming the bulbs you replaced are in good condition.
Old Aug 9, 2007 | 03:36 AM
Default Re: (phootbag)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phootbag &raquo;</TD></TR><TR><TD CLASS="quote">Bulbs that blink fast are usually caused by a high resistance issue rather than a short. I have encountered a bad connection that caused the turn signal to activate twice as fast just like it would if one were burned out. I suspect a voltage drop somewhere, assuming the bulbs you replaced are in good condition. </TD></TR></TABLE>
I'm not sure if I quite understand that... if you have higher resistance and lower voltage your going to get a current drop as well, I don't understand how that would speed up the light?
Old Aug 21, 2007 | 06:34 AM
Not to bring this back but I'll tell you what I found: The Dbags that replaced the pass. headlight used a different turn signal bulb/harness...they used a 2wire vs honda 3wire...they left the other end of the ground wire hanging at the loom creating a voltage issue. Fixed for $5 from oemhondaparts.
Old Aug 21, 2007 | 06:39 AM
good for you.im happy you got it fixed.
Old Aug 21, 2007 | 06:14 PM
phootbag's Avatar
The high resistance in the circuit simulated a burned out bulb.
Old Aug 22, 2007 | 12:08 AM
nickEM2slo's Avatar
damn my first thought was blinker fluid.
Old Aug 22, 2007 | 02:31 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phootbag &raquo;</TD></TR><TR><TD CLASS="quote">The high resistance in the circuit simulated a burned out bulb. </TD></TR></TABLE>
It's coming together now... I'm still on a very elementary level of electricity
MDAMP2005
Oct 31, 2018 06:51 AM
mr poo
Honda Civic (2006 - 2015)
Jun 21, 2018 11:18 AM
TimVanScyoc
Mar 31, 2017 03:22 AM
Acethriller
Lighting
Jan 4, 2014 07:58 PM
acura1masco
Acura TL, RL & ZDX
Jun 7, 2007 08:32 PM
