jrsc on single cam
ok a friend wants to sell me one, but are you suppose to hear it whine because i dont. Ive done turbo single cams but never a super charge. it does make 8pound of boost though. ne help would be appricated
I am not sure what you are asking, but all JRSC on SOHC's I have heard have a whine to it...also 8 psi is not a problem.
thread = ???????
Please search, tons of threads concerning JRSC and SOHC's have been posted
thread = ???????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garageEF »</TD></TR><TR><TD CLASS="quote">if it makes boost then it obviously works......</TD></TR></TABLE>
some of the newer JRSC kits have silencer holes cast into the manifold/blower.
also.... what sort of bolt ons are you running? stock intake arm and airbox?
a short ram will make it louder.... a cold air will actually quiet it down a little and actually make the blower work harder. (less power on most cases)
my old setup was pretty loud, even on 4-5psi.
http://myspacetv.com/index.cfm...61607
the jrsc's are actually quite quiet, mine is running at 8-10psi and you can't tell that its on there except for the little extra power.
as for the short ram intaking being better, i have heard alot of people say this, but i just dont see how a cold air intake would make it work harder, the physics of it just dont make sense.
its like sucking air through a longer straw.
ive dyno'd a few different intakes on my old setups, i recommend a short ram with larger diameter. (3 inch)
yes, heat is an enemy with the roots blowers, so one would think that a cold air would be better..... but it isnt. sort of cancels the purpose.
fuel coolers and intercoolers work really well to make that power up for the heatsoak.
it has a short ram intake the charger is on a duel cam zc im goin to take it off now... i may not be able to hear it also cause its tuned obd0 and it throwing code 4,8,15 and breaking up when i drove it...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaman177 »</TD></TR><TR><TD CLASS="quote">it has a short ram intake the charger is on a duel cam zc im goin to take it off now... i may not be able to hear it also cause its tuned obd0 and it throwing code 4,8,15 and breaking up when i drove it...</TD></TR></TABLE>
ahhhh..... well, its not the charger itself.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaman177 »</TD></TR><TR><TD CLASS="quote">it has a short ram intake the charger is on a duel cam zc im goin to take it off now</TD></TR></TABLE>do you have SOHC engine? DOHC ZC JRSC won't fit SOHC engine, unless it is a SOHC JRSC using some sort of intake manifold adapter
because not only is the supercharger sucking in the air.... its also compressing it.
an N/A engine is also and air pump, drawing in air.... and well, i guess the air is compressed too to an extent in the cylinders. but, for some odd reason, the roots blower responded better to short ram intakes....
funny thing is, a velocity stack had no effect on performance for the SC engine too.
