LED Spoiler Brake light needed
Old Aug 7, 2007 | 06:02 AM
Burnt Toast's Avatar
Default LED Spoiler Brake light needed
My 99-00 si spoiler brake light is bad and I want to replace it. Does anyone have a source for a replacement? I've searched H-T and couldn't find anything useful.
Old Aug 7, 2007 | 10:03 AM
Default Re: LED Spoiler Brake light needed (civic stud)
bump
Old Aug 7, 2007 | 10:23 AM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic stud &raquo;</TD></TR><TR><TD CLASS="quote">My 99-00 si spoiler brake light is bad and I want to replace it. Does anyone have a source for a replacement? I've searched H-T and couldn't find anything useful.</TD></TR></TABLE>
Are you sure it's the LEDs? Those are supposed to last for 100,00 hours or something guaranteed. It may also be the wiring connection.
You could also try contacting Honda. Pretty sure there's no replacement available unless you make one yourself.
Old Aug 7, 2007 | 10:34 AM
BlackoutVTi's Avatar
Default Re: LED Spoiler Brake light needed (wiZCo)
Talk to Honda.
Old Aug 7, 2007 | 10:48 AM
I unbolted and unplugged the light and checked for continuity.Wiring leading to led is good. I assume that I should have continuity trough the plug for the light, but it doesn't have any. How do you check if an LED is good?
Old Aug 8, 2007 | 04:05 PM
*Update*
I hooked it up to a 9 volt battery and it works. Apparantly you can not do a continuity test on them, trere must be to much resistence.
TwoKSiR
Apr 18, 2018 07:04 AM
protoman17
Apr 9, 2018 06:06 PM
PR8urVtec
Nov 6, 2015 05:24 PM
stealthdc2
Mar 21, 2006 02:27 PM
tomy_r
Dec 9, 2004 07:56 AM
