UK Accord Type R U2Q7 LSD information
Old Aug 7, 2007 | 05:48 AM
XES's Avatar
XES
Default UK Accord Type R U2Q7 LSD information
Now that I temporarily reside in Ireland and have acquired an ATR and also ATR spare U2Q7 transmission, I got my hands on a service manual.
Here is the info from it for everyones information (and to clear up that it is 100% not a viscous-type LSD like USDM lsds, etc):
Limited Slip Differential (LSD) (H22A7 engine model)
Function
Operation of the helical type limited slip differential (LSD) is dependent upon the eight pinion gears that are in mesh with the two side gears. They transfer the driving power to the driving axles as well as permit the outside wheel to turn more times than the inside wheel when the vehicle goes around a turn. All gears are helically cut so that this differential action is limited by the friction created between each gear and differential carrier when either wheel slips.
Construction
The unit consists of the two side gears, four short pinion gears, four long pinion gears, two thrust washers, a center washer, and a carrier that houses the gears and washers. One short and one long pinion gear are in mesh with each other and are allowed to walk around the side gears.
When rounding a curve
When the vehicle rounds a curve, the differential allows the outer wheel to rotate a little faster than the inner wheel. When this takes place, the short and long pinion gears rotate, and walk around the side gears in the directions shown. If, for example, the right shaft is rotated in a counterclockwise direction with the differential carrier held stationary, the force is transmitted through the right side gear, short pinion gears and long pinion gears to the left side gear, causing the left shaft to rotate in a clockwise direction. This allows the outer wheel to turn more times than the inner wheel when the vehicle goes around a turn.
When limiting differential action
The limited slip differential (LSD) acts to limit the differential action when either wheel slips on ice or snow or on turn. This is done by using the friction created between each gear and differential case:
(1) The pinions are forced against the differential carrier by the force as they are rotated and repelled outward in engagement.
(2) The ends of the pinion gears are held firmly against the differential carrier due to the side thrust from the helically cut gears.
With the pinion gears locked, the torque applied to the slipping wheel is reduced and the torque delivered to the other wheel is increased.
Modified by XES at 8:00 AM 8/7/2007
Old Aug 7, 2007 | 06:53 AM
PirateMcFred's Avatar
Good post XES! Haven't seen you around here in a while.
Old Aug 7, 2007 | 08:02 AM
Mykizism's Avatar
so they are gear type lsds like quaife's lsd's.. good stuff
Old Aug 7, 2007 | 09:05 AM
mgags7's Avatar
Cool info, thanks
Now I want to know where my old viscous LSD came from....it was in an m2f4 fyi
Old Aug 7, 2007 | 01:59 PM
MLBZ521's Avatar
To good information.
And
To taking the time to type it up AND making it look clean.
Awesome man!
XES
Jul 27, 2012 11:56 AM
^AnDre^
11
Feb 24, 2009 04:58 PM
Nsane1
11
Jun 23, 2004 04:02 PM
Heisdan
Aug 22, 2003 12:44 AM
junjun
Oct 10, 2001 06:16 AM
